  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    Ramón G Castañeda
    No, I didn't miss it. It's irrelevant to what I've been saying, and it is irrelevant to your fallacy that the wide gamut of a monitor influences the conversion. It DOES NOT.
    As I wrote earlier:
    If your workflow is well managed, the final sRGB image will be the same from a wide-gamut monitor and from an sRGB monitor. The pixels will be the same.
    Of course an untagged image is crap. Of course a non-color-managed workflow is crap.
    With a wide gamut monitor you see crap more clearly than with a narrow one. Just like pointing the Hubble at manure. But the nature of the manure remains unchanged.
    December 5, 2007
    >That all goes out the door as soon as the SFW preview window or Firefox or ANY non-colour managed environment enters the picture.
    You must have missed this part.
    Ramón G Castañeda
    Raven,
    >Ramon, you keep pointing me back to proper colour managed workflow.
    Duh!
    I want to be a pop tart for Christmas.
    Gee, looky here, now Raven's the expert!
    These forums are miraculous.
    December 4, 2007
    Raven,
    You are correct. All this technology isn't perfect. If you knew exactly what it takes to make this stuff work as good as it does under the hood you'ld think these programmers and computer hardware manufacturers were gods.
    They make magicians seem boring and contrived.
    December 4, 2007
    Sorry Tim, I don't think I can help you. My guess is that either the calibration isn't accurate enough on the monitors, or that differences between the two monitors are too great to overcome.
    December 4, 2007
    Raven,
    I'm having subtle color issues between my Samsung CRT and my 20" iMac both calibrated by i1 Display. The sRGB water/rock image I posted in this thread looks slightly different color managed or not where the rocks viewed on the CRT look slightly yellowish but look a bit brighter and bluer/pinkish on the iMac.
    Both displays show identical color temp and neutrality. I even visually adjusted the CRT's white point bluer to match the iMac which i1 Match software reads at 6300K and it didn't change the slightly bluer/pinkish appearance in the rocks. The iMac has a slightly wider gamut mainly in the blues than the CRT's with both being pretty close to sRGB.
    December 4, 2007
    I'm extremely grateful Peter that you get what I'm saying. Ramon, you keep pointing me back to proper colour managed workflow. That all goes out the door as soon as the SFW preview window or Firefox or ANY non-colour managed environment enters the picture. If I had a crappy monitor profile, I'd be seeing crappy colours within the colour managed environment of Photoshop. I'm talking specifically about the SFW window, that's it and that's all. That's what this thread is about. I never send untagged images anywhere, except for web-bound images, because at this point in time the number of people using colour managed browsers AND calibrated monitors is too small for me to justify the added file sizes. Actually, I'll probably start including tags from now on for larger photos (but not buttons and stuff) just for the benefit of those precious few people.
    Yes of course it doesn't make sense to assign Adobe RGB to an sRGB image, and I'm not recommending it. I use that merely as an example to illustrate my specific point.
    Maybe the analogy could be improved...yes I understand that a monitor doesn't have a native language...I could say instead that Adobe RGB includes the trilled R sound that is part of the Spanish language, and sRGB doesn't. So a monitor is like a stereo speaker...it doesn't know what a language is, but it can produce sounds. A wide gamut monitor might be able to produce that trilled R sound while a standard monitor can't. Doesn't mean the monitor is Spanish, just that it's capable of producing Spanish sounds.
    >I did not completely read your last two posts, Raven. You're still totally wrong.
    You're missing what Raven is getting at. The example Raven wrote is correct. If you take an untagged image that used to be sRGB, and view it on a wider-gamut monitor in a non-colour-managed app, that image's colours will take on the characteristic of the wide-gamut display, as if the monitor's profile was assigned to the image.
