  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    December 1, 2007
    >Just wondering if there's any practical advantage to having a wide gamut monitor.
    A valid question, since as has been pointed out CMYK fits handily within sRGB with room to spare, and most monitors out there right now are closer to sRGB. I also just read something about most OSes, video cards, cables etc not being able to provide the full gamut to a wider gamut monitor anyway. So a wide gamut monitor currently is basically useless for print OR web work. So what's it used for?
    Right now it seems to be more gimmick than practicality, especially for these kind of non-spec (not sRGB, not Adobe RGB) wide gamut monitors. It's just a sales tool..."look at the crazy colours on that thing!"
    If wide-gamut is the future of monitors, then perhaps sRGB will be outdated one day, and it'll be a "convert to Adobe RGB" (or something) button in SFW. In the meantime, given the fact that wider gamut is rare in monitors, it's surprising that there isn't more support for these kinds of questions. And I'm still looking for a way to gain more control over non-colour managed display. The answers are elusive.
    December 1, 2007
    Uh, commercial press printing is done with 4 color inks(most of the time) CMYK. If you let some dolt at the printshop convert your files you are certainly guaranteed to get a crappy conversion. A wide gamut monitor will not help you with this.
    I thought AdobeRGB was better suited for the printing industry. Just wondering if there's any practical advantage to having a wide gamut monitor.
    December 1, 2007
    >What's the advantage of a wider Gamut monitor... I mean, I tried a conversion to CMYK the other day and it still desaturated, as usual... just like before the Dell. Will it give me a more accurate representation of CMYK inks than the Apple??
    No. CMYK is a much smaller color space than RGB.
    RGB is transmissive
    CMYK is reflective.
    CMYK will always look duller than RGB especially if you don't know what you are doing.
    One more thing.... The new Aluminum iMac has a brighter, possibly wider gamut monitor (I had one for 4 days) and read all the terrible comments about how you can't calibrate it. I think the look, saturation, color, whatever, is similarly saturated... I didn't check out the SFW thing tho. Anyone know about this?
    The color boost on SFW just throws me.... but I am getting better at ignoring it.
    I do use Firefox alot and things look much different.
    What difference does it make what millions of ninnies see on their crappy monitors?
    Keep your Dell and make it look right to you in the wider gamut, get some advice from them and from calibrator vendors.
    November 30, 2007
    jefbak - Not sure then...if you still have CS1 installed you could go through all of the SFW menus and settings and confirm that they are the same in both versions. I have CS1 and CS3 here and am having identical performance in both. Check both SFW menus...the one above the right side of the preview window (includes "Browser Dither" etc.) and the one to the right of the Preset menu.
    Peter M - I haven't yet heard of a way to have the Dell operate using sRGB and still be calibrated. Without that info, you can keep the Dell and continue converting to sRGB on output through SFW, ignoring the colour boost with the assumption that it will appear more normal on most monitors...or you can ditch the Dell in favour of a more normal monitor.
    Anyone with some insights on how to achieve sRGB behaviour on wider gamut monitors?
    I've got the over priced, low-color, plain vanilla, sRGB Cinema display ordered from Apple now... arrives on Tuesday, Dell 2407-HC sitting right next to it's box... what the F should I do!!???? Is there a problem with my monitor, the calibrator, Photoshop, the world, what?! I cannot afford both and barely can afford the Apple... X-Mas is coming and kids are having babies, etc, etc..... I need some sound advice here, and FAST... No lectures please... I promise to stop bashing Photoshop and I'll sign up for a class if someone here starts one!
    jefbak
    Converting to srgb in cs3 gives the same problem.
    What else could adobe have changed? I will probably open a support call on this today or Monday.
