  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    hmm...
    and why do you need my input if your questions are being answered by Peter?
    November 30, 2007
    jefbak, it may be a difference in settings between CS1 and CS3. What colour profile is the source image using and do you have "convert to sRGB" checked in the SFW options menu?
    Ramón G Castañeda
    > Monitors are not the direct cause of any seen discrepancy.
    Agreed.
    PEBKAC plain and simple.
    Monitors are not the direct cause of any seen discrepancy. It is the simple fact that some models of newer LCD screens have a larger display gamut than older monitorsl, which, more or less, conformed close enough to sRGB that it didnt' matter much. There are more options in CS3 SFW, so you have to be aware of what they are when you go that route, and know that viewing untagged images in a non color managed app may result in your brain getting twisted more than this thread has already done to several participants.
    jefbak
    Still confused here. Is this thread about monitors causing the issue?
    Is there a difference in save for web and devices between cs1 and cs3 using the default settings on each version?
    If I am seeing the image one way with save for web cs1 and another way with cs3 save for web, what could that mean?
    November 30, 2007
    g ballard and Mike Ornellas, what is the point of saying "hmmm..." and nothing else? How does that help anyone? Seems to me like you are merely being insulting.
    I am probably just fanning the flames by even commenting on this, and should have just ignored it. I just get so tired of such comments, it's hard for me to ignore. But I'll work on it.
    November 30, 2007
    Mike. What are you listening for?
    You're completely nuts if you return that monitor. Get your calibrator vendor to tell you what to do.
    NTSC is only a space for good CRTs anyway. I mean, come on, it's television, give me a break. Nothing to do with Adobe RGB and advanced display technology.
    CCFL is still fluorescent.
    Im listening Raven
    November 29, 2007
    "hmm.....x2"
    Can you elaborate? x2
