  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    November 29, 2007
    "...or get a more sRGB compatible one"
    So I guess you have to look at the specs of different monitors to find out which one is closer to sRGB?
    > I'm returning a high color monitor because photoshop is unable to provide a solution for browsers that are unable to deal with this.
    hmm...
    hmm....x2
    jefbak
    This thread got off on the monitors direction, but we are having this problem when updating gif images created in photoshop cs1 which are then edited in CS2 or CS3.
    All versions are installed with their default settings. The color of the CS2 and CS3 images look different then CS1 versions.
    All on the same mac pro and 30" apple monitor...
    Is there a settings change to get CS2/3 images to match CS1?
    You're right, I'm back.... I edited my other message... I'm not trying to piss anyone off, I'm just really annoyed with the experts that will not understand my dilemma. I have been screached at for a long time in here, and finally the realization that my monitor is fine, but the majority at large just isn't compatible.
    Turns out I do not have a cheap, crappy monitor with a bad profile.
    Gee... sorry Pete, wow, we've all learned a great deal throughout this whole thing. Well, now you have a decision to make, keep the wide gamut monitor or get a more sRGB compatible one. Interesting stuff... hope this helped... good luck!
    But no.... Hmmmmm......
    November 29, 2007
    "hmm..."
    Can you elaborate?
    November 29, 2007
    I think I would rather have a monitor that has a gamut that is closer to AdobeRGB then sRGB. One of the places that makes my Giclee prints has me use the AdobeRGB profile. As far as saving images to the web, I can deal with the workaround fine...
    "Thanks to all... it's been great... bye!!!!!!!!!!"
    You'll be back... Blind
    Well thanks for the help, I don't know what else to do then. I will return the monitor and move on. Maybe one day I will re purchase a full spectrum monitor (or whatever you call it).
    I just think PS should offer some kind of solution or help, maybe a warning message, or a special calibration button or whatever.
    hmm...
    November 29, 2007
    To go one step further in defense of Photoshop...when I select my calibrated profile before closing the Display Preferences window - Photoshop displays an oversaturated image. Once I close the Display Preferences window (committing to the monitor profile), the image desaturates to a more normal appearance, suggesting that Photoshop is recognizing that the gamut is "too wide" and compensates for that to display "correctly". Same with colour-managed Safari.
    I don't know if I'm quite right there, but it's making sense to me right now.
    November 29, 2007
    Peter M., I hear what you're saying although I'm not sure that it's a Photoshop issue. Colour managed images display correctly, whether in Photoshop or in Safari...it seems that methods of dealing with un-tagged or non CM images are lacking. My two cents.
