  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    November 29, 2007
    I agree Peter, I am seeing a lot of banding in gradients, eg. a very noticeable jump in colour at the border of colours differing by one single RGB number. (This is probably not just because there's a larger difference between R154 and R155 in a wider gamut, but due to inferiorities in the monitor and/or profile.) Perhaps in future monitors will have 16-bit display, and someone will offer system-wide colour management options with more customization.
    I am considering emailing Dell to see what they have to say about my desire to have this monitor operate closer to sRGB. Unless someone here knows of a way to do that. To my still relatively naive mind, it doesn't seem like it shouldn't be so difficult -- seems like it should be a part of the calibration process.
    There are still gaps in my understanding and I have more to learn, but I have learned a ton in this sprawling mega-post.
    Ya great... so I'm returning a high color monitor because photoshop is unable to provide a solution for browsers that are unable to deal with this. My frustration is that there is no other solution, but there should be! Things change, things progress forward, people will always holler and scream about it. The world is round I tell you!
    The good news tho is that only people with this monitor or similar, will have trouble viewing untagged sRGB images on the internet.
    I wonder if Adobe could add this button to photoshop (see image below)
    http://www.hostzombie.com/cs3/button.jpg
    [large image replaced with its link]
    This entire thread seems to have perfectly illustrated the theory of unintended consequences. On the one hand, larger monitor gamuts certainly do seem like a good thing, but there is a lot of catching up to do in other areas. Similar things happened to applications like Quark Xpress when we shifted from calibrating to gamma 2.2 from 1.8. The non color managed interface of the earlier versions got too dark and contrasty. There are other problems with high gamut displays in critical graphic use that have not been talked about here. The data path is currently 8 bit through the entire path, and with large gamut displays, combined with the tweaking of the video lookup tables in the graphics card to carry out the monitor calibration, on screen banding can be a real problem, especially in subtle gradients. For the type of work that I do, dealing with on screen artifacts and banding that are not actually in the file, but only a product of the monitor itself, are completely unacceptable. Hopefully, all the issues will be dealt with by the time my three Sony Artisans finally wear out.
    November 29, 2007
    Peter,
    Then if the images look different between the two then it's the gamut difference issue and not a system level problem. That's good.
    Nice to know they're making great improvements in LCD displays. We can always use more color. Now all the more reason to use color management even with the web.
    It's a Samsung s-pva panel
    Here's a quote from ZDnet:
    For what it's worth...
    "The sixth "HC" revision increases the image quality once more by bringing High Colour to the table, meaning the screen is capable of displaying 92 percent of the NTSC colour gamut, compared to the 72-76 percent of old. For the non colour geeks out there, this means that a lot of colours that were being "lost" on older monitors -- that is, being displayed inaccurately -- can now be seen on screen. This should please everyday users and amateur photographers alike, although colour professionals will probably still keep a properly calibrated CRT somewhere for safety."
    Tim: I'm using Safari... I'll check Firefox and PS... OK, well it looks the same in FF, but I will say that there is definitely less saturation in Photoshop, the pond photo has no embedded profile, so I assigned sRGB 2.1 upon opening... no pinkish or any color stands out over any other. It does look more natural in PS. Great in fact.
    Not sure how to check for the profile issue... it has been very consistent right from the beginning.
    Don't forget, and I have posted this before, I do see the same type of saturation shift with my G4 and Sony CRT but no where near as severe and barely noticable, it is a saturation increase non the less. Both running PS CS3
    November 29, 2007
    And I just remembered. There's a way to know for sure what panel you have with the Dell at least it worked on the 2007wfp.
    You may have to get the instructions to access the ROM for the model you have, but the way it worked on the 2007wfp was to turn the display off with the front button and turn it on again while holding down the OSD menu button for about 3 seconds or until the screen is nolonger black and the first color appears and then let go and then hit the + or - button. Do a search on the web. That's how I found these instructions.
    This will access the ROM section of the display at the level the factory used to set up all default settings like hue, saturation and a myriad of other complicated parameters. When this menu appears at the top it should read LG or Samsung and such and such model number.
    November 29, 2007
    Peter Mars,
    Hang on a second. You said that image I posted looks natural? How can that be since it's sRGB? It's suppose to look overly saturated in nonCM browsers.
    View the image both to compare in PS honoring the tagged sRGB profile and in your nonCM browser. They should look different much the same according to what you've indicated with your own images.
    If they don't you have a bad monitor profile or your system is referencing the wrong profile PS uses to give correct looking CM previews causing you to edit the saturation levels inaccurately. It's happened before even on Windows systems. Something doesn't get written in the write place or clicking doesn't make things stick or something happens at start up to cause things not to load correctly.
    Here's a marketing quote from back in June.... "Dell today released the UltraSharp 2407WFP-HC, a new wide color gamut version of the 2407WFP LCD display. The new Dell 2407WFP-HC uses "wide CCFL" technology to provide a wider color gamut.
    The firm claims the new 2407WFP-HC can display 92% of the NTSC color gamut, most LCD displays can only show 40 to 70 percent"
    Make your own decision, I have been working with this monitor for 3 months now and I believe it... everything posted here points to this, and I for one find no other possible explanation. I have repeatedly stated that the colors are amazing and way too much to handle. The point to all this is that the monitor is so far from normal as to make it not suited for some photo processing operations... by todays standards anyway. Images look normal in color, but without tweaking this monitor is beyond bright and vivid! It may be good for many things, but certainly not sRGB web design.
    During this whole process of discovery, I have also discussed the results and limitations of the HueyPro with a color scientist at Pantone/x-rite and received, at no charge, a completely new version of the HueyPro that they claim has improved contrast handling ability, specifically designed for "certain" wide-gamut monitors. I believe verything is fine with the calibrtion and profiling.
    Id keep it if I could afford 2 monitors..... I will gladly accept donations towards this end, thanks.
    "Life is what happens while you're making other plans" - John Lennon
    November 29, 2007
    Ramon, do you have any suggestions on how to create a profile for these Dells that is is colour accurate, targeted to 2.2 gamma and 6500K AND is closer to sRGB?
