  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    Good point, Ramon.
    If Dell has managed to get that close to Adobe RGB without using LEDs I'd like to know how they did it. Fluorescent backlight has a very weird red component( as do CRTs) that everyone has learned to live with up til now. LED backlight has much better color spectra. I suppose it's possible that Dell has modified the fluorescent somehow, but I still doubt it. Maybe they have improved their RGB filters in some way. I personally have liked the Dells ever since they started branding somebody's panels as their own.
    Ramón G Castañeda
    Peter Figen and Dirk: <br /> <br /> Don't lose sight of the fact that what appears labeled as "Dell gamut" on the graph posted at Pixentral is only the profile created by Peter Mars for his Dell Monitor with the Huey, and is not to be taken as the gamut of the Dell monitor per se. <br /> <br />c <a href="http://www.pixentral.com/show.php?picture=1TuavVHZtb0coWT6ALWkb7zKE2CNBM0" /></a> <img alt="Picture hosted by Pixentral" src="http://www.pixentral.com/hosted/1TuavVHZtb0coWT6ALWkb7zKE2CNBM0_thumb.jpg" border="0" /> <br />c Click on thumbnail to see full image again <br /> <br /> I suppose I could create a spurious profile that far exceeded ProPhoto RGB and pass it off as my monitor profile, which would be absurd. In other words, one has to take into account both the tolerances and accuracy of the Huey as well as possible human error.
    Tim: I would say everything looks natural... good color, not oversaturated. Rocks look tan, dirt looks slightly warm, similar to rocks but darker, not grey or neutral.
    Lowering the brightness causes trouble at this point. B=25 and C=85. In my case, Brightness is really black level and contrast is max white if you will. I have tried all of this and these are the most accurate settings. Lowering contrast (white point) doesn't help with saturation shift using SFW.
    I read that if my serial number ends in an "S" it means Samsung... it does. That's all I know.
    Color is great, I love it.
    Peter F: Progress is inevitable... as always. I'm just tired of wrestling with this. I just do not to wake up tomorrow and find that the world has changed to this new standard and I've just returned a good monitor I got for a super price. I still can't get over that it's so close to aRGB!
    Thanks again for your input.... love your photography website by the way! Classy and cool shots!
    I think that soon most browsers will read embedded profiles. Maybe if they are profile savvy you could also designate assumed profiles.
    November 29, 2007
    Peter,
    The sRGB tagged image I posted do the rocks look pinkish and/or oversaturated including the water or is it natural looking?
    What happens when you turn down the brightness of the display the same level as a sheet of white paper viewed under your current lighting arrangement? What kind of calibration results do you get then?
    It sounds like you might have an S-PVA panel. I've read comments how vivid Samsung brands of LCD TV's and computer displays are from other users. And everybody just loves the way they look.
    Ya, weird to say the least... it is a very colorful and bright monitor. I have tweaked the OSD RGB sliders and that's the profile I get. It is even more colorful with R-G-B all set to 100%
    If only browsers assumed sRGB instead of MonitorRGB... who's idea was that anyway?
    November 29, 2007
    mmh, I didn't think this thread would go on. You miss a lot when you leave to run errands. <br /> <br />I didn't think I'ld see Dell displays with such a large gamut. It doesn't really do you much good viewing web color since the size and shape of the gamut kind of puts you in color limbo between sRGB and not quite AdobeRGB. <br /> <br />I don't suppose reducing the saturation and adjusting the hue OSD sliders if any exist got you closer to sRGB. <br /> <br />Dirk, <br /> <br />I nolonger reside in Kerrville. Just moved two months ago to New Braunfels, Texas, the place I've been wanting to live since I saw Landa Park in my early '20's around 1980. The park has the most crystal clear bluegreen spring water rivers coming straight out of the rocks and river banks. <br /> <br />Been to Fredericksburg, nice sleepy little town just like Kerrville, but with more upscale professional types. Haven't yet made my rounds viewing the hill country sites yet which there are many. <br /> <br />Check out why I moved from this shot of one of several Landa park streams I took on my Pentax K100D with some editing in PS. <br /> <br /> <a href="http://www.pixentral.com/show.php?picture=1QRSEUGyGoArs2BxDCvSozkQzM1pL3" /></a> <img alt="Picture hosted by Pixentral" src="http://www.pixentral.com/hosted/1QRSEUGyGoArs2BxDCvSozkQzM1pL3_thumb.jpg" border="0" />
    Interesting... thanks very much. My eyes have not been deceiving me after all. I still have no idea what this means, other than no one else can view anything I create in quite the same way. I suppose this doesn't change anything, I still need a more mainstream compatible monitor. Thanks again for doing this.
    Here ya go...it's a bit of a pain in the ass to get representative views that show everything in one still image. When you are viewing the maps, you can scroll and see them from any angle, side or top to bottom, as well as adjust the wireframe opacities and colors to suit, but this should give you the basic idea. This Dell is not quite Adobe RGB, but it's much much larger than sRGB. A picture is worth 400 messages.
    November 29, 2007
    Peter F... Please post the profile thing in this thread so we can all see...
