  • October 31, 2007
  • 680 replies
  • 62289 views
Pete
    pfigen at keyway dot net
    Not seeing the email on my end. Which one did you send it to?
    I'm gonna guess that it's fairly close to AdobeRGB, but green may be off slightly because images appear to be just a bit too saturated in green areas.
    Profile sent... thanks a lot!
    The ColorSync Utility is kinda rudimentary compared to ColorThink, but it's free with OSX. If you can email the Dell monitor profile you made, I'll post a comparison from ColorThink. Click on my name to find the email.
    OK, I will do it... sounds great! Please explain a bit more about what you need and where I can find it.
    Compare gamut maps in the ColorSync Utility or preferably ColorThink, if you have it. If you email me your Dell profile, I'll pull it up in ColorThink and post a jpeg comparing that gamut to sRGB, Adobe RGB, etc.
    Is there a test to determine Monitor as AdobeRGB ?
    This would explain why untagged sRGB images get mapped to an oversaturated look... no?
    sRGB mapped to AdobeRGB (MonitorRGB) produces oversaturated color right?
    >I very much doubt that Dell has managed to achieve Adobe RGB
    My only proof, or indication that AdobeRGB may in fact be what the monitor is displaying is that when I rollover the gballard.net adobeRGB image test, I see virtually no change in color or saturation whatsoever. So minimum is the change that I could not honestly say whether it is more or less saturated. The sRGB rollover test causes a huge shift however, and Apple RGB cause a substantial shift as well.
    I assumed that this means the monitor is displaying AdobeRGB natively. I also know that dpreview forums refer to this monitor as a "wide gamut" monitor.
    You get a color boost because, the specific recipe of pixel values in sRGB represents a more saturated color in Adobe RGB. Same numbers, different color. That's why it's so important to know what the context of the numbers is - what profile is the right one that describes THAT color space.
