  • October 31, 2007
  • 680 replies
  • 62211 views
Pete
    Peter,
    Just for kicks, what happens when you take your SFW image - the one you say gets ubersaturated - and open it back into Photoshop and then ASSIGN your sRGB profile?
    It's highly unlikely that your sRGB profile is corrupt. Never heard of that.
    >Most of them assume Monitor RGB, not sRGB
    First of all, my Canon 40D does not use sRGB 2.1... it uses something called "Camera RGB Profile" so I open and convert to sRGB 2.1... next I tweak and do whatever to the image, then I hit SFW and this is where it gets crazy. If I set the preview menu triangle to "uncompensated color", I see way too much saturation. (not like what I see in photoshop working window) If I set the preview menu triangle to "use document profile" it displays exactly the same as in photoshop. low saturation, normal, etc. This is a false display however, because the minute I hit the save button, the high saturation is locked into the image. No matter what I have anything else set on.
    It looks to me like photoshop is ignoring the sRGB conversion when saving, or overcompensating for the monitor profile... like it's putting back the color shift that the monitor profile took out in the first place. It seems to me that the monitor profile should be respected at ALL times. As if it weren't even there. Like it were a permanent filter. Like people wearing glasses what's the point of ever taking them off. No comparisons will ever be valid without them... or in this case, the monitor profile.
    I understand what you are saying here, my setup is just not following the protocol.
    Is it possible that I could have a corrupt sRGB 2.1 profile???
    "non-color managed browsers assume sRGB"
    Most of them assume Monitor RGB, not sRGB, and, as has been stated here several times, the further your screen is from sRGB, the bigger the shift you're gonna see.
    As far as your softproofing scenario is concerned, it really depends on the source image. If your source RGB image doesn't have any colors outside of your CMYK gamut, you won't see any difference, but if you have a highly saturated image, you surely will see a difference between the CMYK soft proof and the sRGB soft proof.
    Ramón G Castañeda
    >Softproofing in WorkingCMYK and WindowsRGB is identical, and unchecking ProofColors produces no change to either. Strange that both these spaces should appear identical to sRGB 2.1
    If your monitor's gamut as calibrated and profiled is smaller than all those three spaces, or if the actual color space of your image is narrower, I wouldn't expect you to see any difference at all.
    Ramón G Castañeda
    Safari is color managed, Firefox is not (yet).
    If you are seeing what you call a "saturation increase" my bet would be on your monitor being calibrated closer to gamma 1.8 than to 2.2.
    Here's an interesting discovery.....
    Save for Web is causing a saturation increase or profile shift on my machine. This is confirmed by viewing resulting jpeg in Safari and Firefox. Identical results in both when "Include ICC Profile" is unchecked during save. Checking "Include ICC Profile" when saving produces no saturation boost and normal image in Safari, but still causes a saturation boost in Firefox.
    It appears that Photoshop is not saving proper sRGB images. There should be no difference in appearance whether ICC profile is included or not, as non-color managed browsers assume sRGB and I am telling Photoshop to create sRGB images yet they do not display correctly outside of photoshop.
    Raven , your Dell Monitor is not exactly sRGB because it's an LCD, AND, it is miles from being anywhere close to Adobe RGB. You can't get near Adobe RGB unless you have an LCD with RGB LEDS( 6,000 bucks last i knew) instead of fluorescent back light. Furthermore, saying that your monitor looks like a CMYK printed piece just means that you are looking at two examples of CMYK color gamut which is smaller even than sRGB, although it has better blues if I remember correctly.
    You have much to learn, pilgrim.
    November 26, 2007
    I apologize again for letting my temper get the best of me. The fact is, I have learned something here, and it did take 300 posts for the information to become clear to me. Thanks for the help.
    November 25, 2007
    My comment was that the example had minor differences. the OP and Raven said the differences were drastic (My understanding), so that's where I blamed the monitor calibration.
    Buko,
    You wrote in post #297:
    "I not sure what I can add to what yu had explained to you so clearly other than the fact you have a bad monitor profile a crappy calibrator and a cheap monitor."
    and now you write in response to Raven:
    >>SFW means definitively that there is something wrong with the monitor profile?<<
    "No I'm saying that the color shift is so minor from what I see in the screen shot that its not worth worrying about."
    No wonder this is confusing.
