  • October 31, 2007
  • 680 replies
  • 62211 views
Pete
    Raven, understand this. The next time you recalibrate your monitor, the same rgb image you converted before the recalibration will convert to different rgb numbers after the recalibration, and this means that the graphic will look different the second time to everybody else viewing it. This is why people are telling you to use sRGB as your standard to calibrate to. Reason 1, it most closely approximates what most people on most monitors are seeing, so you will please more of the people more of the time. Reason 2, it means you have a consistent standard to convert to that will give you the same conversion result on the same rgb numbers. If you convert to a standard that changes (your monitor profile), the same rgb numbers will convert to different numbers after every time you calibrate your monitor.
    November 27, 2007
    Peter, what seems to be working for me -- call it a workaround, or call it the answer, I don't know -- it to simply convert the image to your monitor profile (whatever you named it after calibrating) and then take it into SFW, and leave "convert to sRGB" and "ICC Profile" unchecked. Gives me the result that I want, looks the same in Firefox and Safari.
    November 27, 2007
    >how can we expect any consistency?
    you can't, this is also what we have been trying to tell you. 95% or more of everyone surfing the web does not have a calibrated monitor. No matter how perfect you get it on your machine, practically the rest of the world viewing it will see something different. but they don't know that neither do they care.
    Remember in the early days of color TV? or are you too young for that? I would visit someone's house and the color would be oversaturated with a green or magenta hue. Sometimes if it was my friends place I would adjust the color as close to normal as possible. The next time I would visit the TV was back to what it was before. The great unwashed masses just don't have much concept about color, what is right or what is not.
    >That's why I recommend beating with a baseball bat any moron that hands you an untagged file
    I hear you... that's all fine and good for print, but there is no way on earth I am going to start embedding profiles in slices and web graphics. I tried this on a project just for yucks the other day, and a simple folder with 75k in total files, shot up to 270K
    I found the profile by the way... it's way down the photoshop list "sRGB Profile", didn't make any difference, still color shift when saving.
    If PS is tweaking images when saving based on monitor profiles, and if "dumb" apps assign/assume "monitorRGB", how can we expect any consistency?
    I just revisited the rollover demo page at gballard.net... I get exactly the same results with the sRGB demo. UntaggedsRGB gives very high saturation and AdobeRGB rollover gives no change which makes no sense to me.
    Never the less, Photoshop is changing my images when saving for web because viewing on other machines, Mac and PC, reveal somewhat increased saturation also. I sure hope photoshop is not assuming my setup is typical of other machines and adjusting my images based on my monitor profile.
    Ramón G Castañeda
    >"Get info" says simply "RGB".
    Yup. That'll be the case with every untagged RGB file you'll ever come across.
    >I do have jpeg images that I made These are the only files that work properly for me and I can't recreate them. Very frustrating because I know it can be done.
    Now you have to guess what color space they were created in and how they were saved. That's why I recommend beating with a baseball bat any moron that hands you an untagged file. :/
    Using a jpg image I just saved with SFW and "No ICC Profile"
    "Leave as is don't color manage" looks fine
    "Assign WorkingRGB" looks fine, both look the same
    I just dropped the no icc profile image on Safari and it looks oversaturated
    I then droped a profile included version on safari and it looks fine
    Yes, that is 100% as expected and exactly what we've been telling you (how it works).
    OK thanks for the food for thought. I will experiment some more.
    I do have jpeg images that I made on a different system with a different version of photoshop that looks exactly the same in every browser I try. PC included. "Get info" says simply "RGB". When opening in photoshop I get the "No embedded profile" message. I have tried assigning every profile and none fit without a color shift. These are the only files that work properly for me and I can't recreate them. Very frustrating because I know it can be done.
    That's because, I think, Safari either assumes Monitor RGB or what Apple calls Generic RGB when encountering untagged documents. So that would make sense.
    I renamed a finder a copy and opened both
    This is too weird!!!!
