  • October 31, 2007
  • 680 replies
  • 62291 views
Pete
    g-
    The grays DID look pretty neutral, though the sample image was pretty small given the resolution of my monitor. The flesh tones looking a little on the cool side was just the opinion of a couple of us here in the studio, more at how We might adjust the flesh tones vs. a scientific assessment of neutrality.
    Craig
    Thank you for the feedback, it is very interesting to me.
    >> sample images of tagged and untagged sRGB files in Safari (Mac) definitely display differently.
    A slight more saturation is expected in the sRGB rollover using proper profiled non-high-gamut LCDs
    The wide-gamut Dell LCD monitor here shows a cartoonish unacceptable red shift especially in the reds.
    >> The tagged file displays fleshtones a little too much on the cool/green side
    The tagged files are calibration files that should display very neutral grays and pleasing, natural skin tones -- so I am wondering why the calibrated Eizo is displaying them on the "cool/green side"?
    You need Safari to view them on the web in a test environment (I noted you were using Mac Safari).
    Using a profiled EIZO ColorEdge CG241W, g ballard's sample images of tagged and untagged sRGB files in Safari (Mac) definitely display differently. The thing is that neither version is really objectionable. The tagged file displays fleshtones a little too much on the cool/green side, and the untagged version is lighter and overly reddish.
    In my opinion, viewing images on the web is like looking at photos on newsprint, I never expect them to be representative. I've been hoping for several years that browsers would observe color tags, and maybe that day is drawing closer, but I think this would require a concerted campaign asking the W3C to put color management in its web specifications.
    In any case, I love the CG241W.
    Craig
    Ramón G Castañeda
    Better yet, make it impossible for any software to save an untagged image. :D
    March 11, 2008
    But doesn't it seem likely that if the wide-gamut Eizo (or any wide-gamut monitor) can switch to an sRGB mode, than that negates any benefit of having a wider gamut available? As far as I can tell the monitor itself is not going to be able to treat untagged images as sRGB while still offering up full gamut to images tagged as Adobe RGB. The only hope as I see it is:
    a) All major browsers begin to recognize embedded ICC tags AND have an option to assume a default colour profile in lieu of a tag.
    b) Similar function is made available -- either included in the OS or available as third-party software.
    My Apple 30" and my other LCDs all show a slight saturation boost in the sRGB pair.
    I remain optimistic that EIZO ColorEdge CG241W ($2,500 USD) wide gamut dual DVI connections hardware has a solution...it would be cool to have this monitor or the Eizo's 30" wide gamut at $5,000+.
    The older Ezio CG240W ($1,600) monitor (non-wide gamut) will certainly work with one DVI and One HD15 connectors, its dual CPU support and Eizo's 5-year warranty beat the Apple 23" hands down...
    All I see is better contrast when rollovered in Safari on a Mac.
    >> the less of a problem it really is
    The problem is it displays 98% of the internet way over saturated on the Mac OS X browsers (and I do occasionally surf the web).
    Eizo is supposed to test on Mac 10.5, Xrite profile and get back to me.
    If anyone is following this saga, I put a very simple test page up:
    http://www.gballard.net/photoshop/srgb_wide_gamut.html
    This should nail the problem and offer two ways to verify it...
    Pull yourself together , g. You can handle this. You've got to, you're our guru. Peter can talk you through this.
    "Is anyone using this monitor, it is high-gamut and I am wondering if the Mac will have the same problem displaying untagged sRGB on the internet? "
    Of course it will. It's not the monitor, it's the fact that the monitor color is a mismatch to the file color space, so ANY large gamut monitor will have the same "problem" if you call it that. The more you understand what's going on, the less of a problem it really is.
