  • October 31, 2007
  • 680 replies
  • 62291 views
Pete
    EIZO ColorEdge CG241W ($2,500 USD)
    Is anyone using this monitor, it is high-gamut and I am wondering if the Mac will have the same problem displaying untagged sRGB on the internet?
    Or the standard gamut EIZO ColorEdge CG240W... Is this screen worth $1,600?
    A follow-up email to Xrite was answered with useless canned out-of-date dribble...
    Dell, on the other hand, said the untagged sRGB saturation boost on the internet was to be expected with the Mac OS.
    They said Windows OS doesn't have the problem on the internet with untagged sRGB (it applies sRGB profile to untagged color on the internet).
    So I booted my Mac Pro into Windows Vista and confirmed in Safari, the sRGB tagged/untagged rollover has zero change and the rest of the internet looks normal.
    So the answer is either 1) Mac OS needs to Assume sRGB on the internet, or 2) Dell needs a Mac button -- any bets on which will happen first?
    So if you have a Mac, don't buy the high-gamut LCD monitors for web work/surfing (unless you are color blind or want a headache).
    It seems likely that Dell, from what you describe, has found a way to produce a wider red spectrum from the fluorescent light, and possibly a better blue filter.
    If you figure out what's going on with balancing the RGB in a Custom RGB preset mode, please let me know...
    I will drop back in after some time working with my last profile and settings...
    How do I know if my puck/software is made for wide-gamut display?
    I spoke with Xrite a couple days ago before ordering this monitor and the tech guy didn't have any info on using his hardware-software package on the 'new wide-gamut LCD monitors greatly saturating untagged sRGB' issues I asked about.
    I read somewhere recently, and it may have been on the Colorsync list, that the preset for sRGB was basically a hardware dumbing down to something close to sRGB, but then you couldn't take advantage of any high bit internal data for calibration. I don't know exactly what's happening there with the options you' re now using, but my guess is that you've now probably used software adjustments in the LUT to do the same thing. While it may solve the untaggged sRGB situation ( I would not call it a problem) it may well introduce other things into the mix like coarser gradients, reduced gamut, and possibly on screen posterization. Also, if your colorimeter isn't made for a wide gamut display, that may be causing you grief too.
    okay, sRGB preset looks like a cheap PC CRT, literally
    I found a CUSTOM RGB preset and it gave me access to adjustable RGB levels (like the old CRT adjustable RGB guns).
    The Eye-One Match software allowed me to balance them out -- all three were maxed 100% by default, and the puck said the green level was way out in front.
    Turning down green and leveling them out equal seems to have corrected the problem in BOTH Photoshop and untagged sRGB -- sRGB> Photoshop> View> Proof Setup> Monitor RGB slightly over saturates the color very much like my 30" Apple Display.
    I am not sure if this is the best answer, but it looks like it is working good here (in Presets Mode> Custom RGB> balance out the levels and build the profile)...
    don't know about exactly but it certainly emulates the problem
    I seemed to have solved the mystery for getting usable color out of untagged sRGB on this Dell Ultrasharp 2408WFP.
    There is a "sRGB" choice in the monitor hardware menu: PRESET MODES> sRGB
    While this likely has a dumbing-down governing effect on the wide gamut this monitor can put out, it makes untagged sRGB a lot more closer to my calibrated CRT and Sony and Apple LCDs.
    This is great because its PC> GRAPHICS>DESKTOP setting is unusable for viewing the internet (unless you like cartoon colors). Even hardware-profiled screen was leaning on the reds in this mode.
    I may look into this more later when I get my used G5, but for now my curiosity is satisfied
    "like Assigning AdobeRGB to a sRGB file in Photoshop "
    That's EXACTLY what you're doing when you monitor space is close to Adobe RGB...
    reds jump a lot -- like Assigning AdobeRGB to a sRGB file in Photoshop
    In all three colors or just red and blue?
