  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    Amen. The choir will now sing, " We Have Been Given Much, We Too Must Give".
    Craig,
    Like a lot of professionals, or maybe not, I work on my images on a hardware calibrated rreference monitor, either a Sony Artisan or a Barco Reference V. I convert web images to sRGB and don't worry about them after that. I know they started out right and that they'll be close enough on most screens. The main thrust, it seems of this endless discussion, is the discrepency between how the images look in Ps and the same untagged image in a non color managed browser. It seems that some folks here are having a hard time accepting that their monitors are not exactly sRGB and some are far from it. Ultimately, it really doesn't matter, and either your images look good or they don't.
    I find it easiest to just not obsess too much about web graphics and images. You can't control how your web veiwers have their monitors adjusted. How many people even know how to turn on color management in their browser, or that they should.
    The color drift is huge in web design, so design flexibly and don't sweat the small stuff.
    I think it is as hard for us photographers to let go of online color as it has been for graphic designers to let go of fixed layouts.
    Craig
    agree and not to make things more complicated - but what a mess this thread is and it speaks volumes to human error - on all sides of the issue and I dont think it will be solved anytime soon.
    The answers are certainly here, but you have to sift through a huge pile of crap to sort them out. The last few posts asserting great monitor calibration as proven by a certain screen to print match, but without really understanding why it might just be coincidental only serves to continue the confusion. Sometimes ignorance really is bliss...
    Another color cluster brought to you by the lack of global thinking.
    I had the same original problem, and this page solved this issue:
    http://tancredi.co.uk/2007/5/13/photoshop-cs3-and-save-for-web-issues
    November 19, 2007
    Another thought... about the Apple Calibrator... some have said you must start the process using a "good" profile, like sRGB. In my experience, it doesn't seem that can be controlled. When I choose different profiles and then start the Apple calibration process, the monitor colours shift back to what appears to be the default DELL profile as the starting point.
    November 19, 2007
    I just realized you meant (I think) my comment about the Dell's "Mac" and "PC" settings. I don't know for sure what they mean, its based on the appearance shift I see when I toggle the settings. The Mac one is brighter in a way that suggests the 1.8 gamma shift. I may try recalibrating starting from the Mac setting, just for kicks.
    November 19, 2007
    Lundberg02: "No. That color space can't even display the limited sRGB gamut."
    I think you're missing my point. I am trying to assert that my monitor is calibrated correctly, based on the matching appearance of the test image on screen and on paper. sRGB doesn't have anything to do with this particular test, it's a CMYK image. My point is: if my monitor profile is so "bad" then should I not see a very noticeable difference in my test image?
    "The Dell settings. How do you know what they mean?"
    I don't know what you mean. Can you be more specific?
