  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    November 15, 2007
    I have to step to Peter's defense here. I am having the same problem as he is despite following g ballard "simple" steps from way back in the earlier postings. I am using the same Dell monitor as he is, but I've used the (apparently) respectable Spyder2 Pro calibration. Furthermore, I've gotten from our printing company a standard test image on disk along with a high quality colour-accurate hard proof to use as a reference. The colours are pretty darn similar between the screen test image and the printed reference image. (This is of course a subjective thing, but there's no way around that.) Yet I also have the same SFW colour trickiness.
    Colour management is by no means simple, and I have by no means got it all figured out. It is very easy to become frustrated, especially when people here are saying things like (to paraphrase) "hey dummy, the answer was in post #23, why the hell are you still here?" Well I also have gone through g ballards "simple steps" and still have the problem.
    I also, like Peter, appreciate the help that is offered as it is clear that some of you know a lot about colour management, and have tried to be as patient in explaining things as we have been in trying to understand.
    I am going to revisit g ballard's "simple steps" ... back to square one ... and will try to post my findings as clearly as possible.
    >> So when calibrating a monitor I should start with sRGB 2.1...
    Yes if using an eye-ball calibrator, by all means I would load a fresh sRGB IEC61966-2.1 profile -- or the monitor's OEM ICC profile is probably better -- and if I started the processes over, I would reload the fresh OEM profile again before starting over.
    If you are using a good hardware/software profiling package (a puck), I don't think it matters what monitor profile is active when you start the process.
    FYI: AdobeRGB has nothing to do with monitors (or any other device). This is why it always looks so bad outside of color-managed applications -- aRGB must always be CONVERTED to a target-device ICC profile...
    November 15, 2007
    So when calibrating a monitor I should start with sRGB 2.1... I was starting off with Adobe RGB (1998). I'll give that a shot. Thanks for pointing that out :-)
    For anyone following this saga:
    Building a custom profile from a defective profile will usually only build another defective profile -- always load a fresh profile in System Preferences> Displays> Color like canned sRGB 2.1 before beginning the built-in Apple calibrator process.
    The fresh canned OEM profiles will usually be free of defects or corruption.
    sRGB works in this case because 1) it is a common monitor space usually very close to the calibrated 2.2/6500 monitor, 2) Monitor RGB matched Source Space, and 3) the canned sRGB profile was not defective.
    The reason color shifts when we strip a profile (in SFW or viewing untagged RGB in browsers) is covered in basic detail at http://www.gballard.net/psd/assignconvert.html and the phenomenon may be seen in action here http://www.gballard.net/psd/go_live_page_profile/embeddedJPEGprofiles.html
    Any Photoshop> View> Proof Setup: Monitor RGB SoftProof (or untagged RGB in web browsers) will show a shift on screen unless the file's Source Space matches Monitor RGB (not a good place to be).
    Lastly, I was impressed the OP stayed in here slugging it out and asking questions when he didn't understand what we said, but I have to wish him good luck now.
    November 14, 2007
    Maybe you got a crappy monitor too???
    Um No it doesn't.... my hand-made, Apple Calibrator profiles show the exact same color and saturation shift. They are bad too? Why won't you believe me? Why would I lie about this? G Ballard explained that there are 2 parts to a profile, one for the system and one for the monitor, that's very helpful. and Yes, it's possible my sensor may be bad. But my Apple Calibrator made profile does not work either and no amount of badgering and insulting is going to make it start working! I have made countless new profiles and all give me an unacceptable color shift. You are welcome to come over to my home and show me how to fix this! In the meantime, please lighten up!
    November 14, 2007
    >That does not prove that my monitor profile is bad... You Idiot!
    Um Yes it does.
    Mike, I will take your advice, thank you.
    I always ask lots of questions, it helps my understanding of things... that's just me.
    This was my first experience at this forum, and I had no knowledge of the hierarchy of experts and long-term participants. Respect must be earned not demanded... I now have great respect for G Ballard... and to him I apologize for any mis-communication or frustration my lack of familiarity with his experience may have caused initially. I tried my best to understand this. It is not intuitive!
    To those here that feel the need to take pot-shots at those with different approaches.... %$#$&!
    Peter -
    It really does not matter if you look at the bigger picture.
    Just go on your way because the world is a mess and you can freely add to it as you will.
    You are so full of **it I cannot even believe it! [edited by host]
    I will repeat this for the last time. No one has explained to me why a profile other than sRGB 2.1 causes a color shift, and why my monitor also causes a color shift, and why that explains a damn thing???
    Can you not understand this? Using sRGB 2.1 for the monitor profile is a test that proves what I'm saying! This is the only profile that does not cause a color shift... why!???
    I have continued to ask questions in an attempt to understand these things. All I have gotten has been disdain and worse! Several other posters have questioned recomendations and procedures by the "experts" here.... I am not the only one. I am not responsible for 200 posts other than the fact that I started the thread.
    I am not a genius and I am not stupid... I have tried to be polite in my questionings and in my responses. I however refuse to fit into your mold and follow along like a good little boy!
    Take it or leave it. You Loud mouthed fool!!!
