  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    g ballard gets a well-deserved award for remarkable patience, way beyond the call, perseverance and accuracy. (should have gotten one a long time ago for his contributions to understanding color management here)
    Peter Mars gets some needed color management information, even MORE important teaching in logic, and if he'll pay attention, a MUCH MORE important life lesson, (which he's still refusing to acknowledge). -
    If you ask someone for help, don't keep insisting that since you're a genius, your understanding of things, and your faulty logic is still right and that the advice you,re receiving must be wrong. Or that your argumentativeness is really curiosity or search for truth.
    Or, to paraphrase Einstein, "You can't keep using the same thinking that got you into trouble to get you out of it."
    I can't count the number of times I had to butt heads with a designer/client, otherwise, intelligent enough to understand quantum mechanics who just couldn't wrap his understanding around the simple concept of overprint/knockout and who got it wrong EVERY damn time, while insisting HIS reasoning HAD to be right as the press proofs from his files came out hosed. Yeah, the inks were obviously at fault.
    Rich
    November 14, 2007
    >I am truly sorry for causing anyone any grief.
    the only person with grief is you because you won't listen.
    Ramón G Castañeda
    Peter,
    >I still do not completely understand
    One last time: Photoshop uses your (custom) monitor profile to display the colors on your monitor; non-color managed applications do not, they ignore it.
    >Do I mark this closed now?
    You can't do that here. You must think you're in some other forum.
    I require more than just orders... I'm a thinker, sorry! I still do not completely understand why colors look awesome with this profile, yet photoshop changes the colors when saving. I truly do not.
    I am willing to wait and see what happens with a new puck. I will no doubt contemplate this for a very long time.
    Thanks to G Ballard, all contributors, and everyone that this thread has touched. I am truly sorry for causing anyone any grief.
    Your problem was resolved in post 29 and here we are 229 posts and two weeks later..
    Please memorize everything g ballard has ever written.
    The profile displays things good to my eye. Better than my hand made Apple Calibrator profile. It turns out that there are 2 parts to profiles, maybe something is wrong with one of them. I won't know the full story until I receive an updated puck. I will certainly let you all know what happens.
    Like G ballard said... the monitor profile may be confusing the issue because it may be bad.
    I understand why using sRGB 2.1 for monitor profile looks the same in Proof>Monitor RGB... they are the same profile!
    When I pick a different Monitor Profile, I will naturally get a color shift. That's why this procedure makes no sense to me.
    Lets wait and see... plus I need time for this al to sink in.
    Thanks for your concern. I hope this doesn't ever happen to you! Nightmare!
    Let's see here Peter, how many times were you told that your calibration was bad? Ten? Thirty?
    November 14, 2007
    Shoulda bought a real calibrator in the first place.
    EyeOne 2
    That's good, let us know how it goes...
    OK Thanks! That makes sense!
    Update #1
    During this whole process, I discovered that I had a bad DIMM riser and got it replaced yesterday. Not sure if makes any difference to color performance, but I would not have checked for ECC errors had it not been for this weird color problem. OWC had sent replacement DIMMs and still had errors. Apple replaced the Riser and all is well.
    Update #2
    I just got off the phone with Pantone Tech Support in New Jersey.... AND THIS IS THE BIG ONE!!! They have a serial number reader application, which I downloaded, that determined my HueyPro calibrator serial number as older... meaning that they have correctd a few "issues" recently. Seems that certain monitor viewing angle technologies can cause anomalies with previous sensor filters. They are sending me a new one!!! Let's hope this solves the problem!!!
