  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    What is confusing your tests is your defective monitor profile.
    Contact your manufacturer and ask them for a replacement puck.
    Also some monitors are known to not work correctly with custom profiles on OS X.
    In overâsimplified terms:
    Each individual monitor profile has TWO PARTS:
    ⢠Part One is used ONLY by the Operating System (OS) and nonâcolorâmanaged applications.
    ⢠Part One tells the monitor how to display the color....
    Thanks for your input on this..... I added the clarification post above before I spotted your reply... thanks!
    >Lastly: Please restate briefly the exact problem with your Save For Web save color.
    And if Convert to sRGB in Photoshop and go to View> Proof SetUp: Monitor RGB duplicates the problem.
    To be more precise:
    SFW in PS CS3 produces image files that have much increased saturation.
    So much so that I cannot use these saved images for website production.
    This change appears to be similar to the results I get when Soft Proofing
    in "Monitor RGB"
    My observations:
    During testing and experimentation, I have also noticed that choosing ANY profile other
    than sRGB 2.1 for the monitor profile under System Preferences>Displays>Color
    produces a noticable color shift when soft proofing to Monitor RGB.
    I assume this is because the Photoshop working space is also sRGB 2.1
    The profiles match, so there is no color shift when softproofing to Monitor RGB
    or using SFW. This is totally expected. Therefore, and according to this behaviour,
    I will always see a color shift with SFW or Softproofing to WindowsRGB
    while using ANY monitor profile other than sRGB. No?
    Final question:
    How do I produce accurate images in Photoshop and save them for web production
    while using a profile that's calibrated for my monitor?
    I understand:
    1) Untagged sRGB in browsers duplicate the problem: "saturation is...boosted"
    2) Tagged sRGB in Photoshop SoftProofing Monitor RGB duplicates the problem: "saturation is...boosted"
    THE PROBLEM IS YOUR MONITOR PROFILE.
    The shift you are seeing is the difference between sRGB and MonitorRGB.
    You proved this by setting sRGB as your monitor profile, and by SoftProofing MonitorRGB and WindowsRGB with zero change on screen.
    I have no idea how much your MonitorRGB space is over saturating untagged sRGB, (unless you are Assigning/Assuming/Applying AdobeRGB profile to sRGB), but like I previously wrote:
    It is normal for sRGB to saturate a bit when the profile is stripped and viewed in a calibrated 2.2 gamma/6500 monitor space, but if is extreme you may have a defective profiling package.
    Try searching your monitor on google for known saturation issues.
    > any profile I choose under >Displays>Color
    I only asked for one profile: sRGB 2.1
    Yes, but I took it upon myself to investigate further
    > Macintosh is light and washed out.
    I only asked for one SoftProof (from Photoshop sRGB): Monitor RGB
    > (you stated) More saturation and brighter colors in "Monitor RGB"
    I am going to repeat myself here for the last time:
    Is that the exact saturation problem you are posting about?
    Yes, it appears to be the same problem
    How much change are you seeing?
    Enough to be very concerned. Saturation is definitely being boosted.
    Yes, this appears to produce the same results
    What monitor model number are you using?
    Dell 2407 wfp-hc
    If any profile I choose under >Displays>Color causes a shift except sRGB 2.1, how does this prove my monitor profile is bad? I would expect it to cause a shift.
    (assuming we are always Soft Proofing for WindowsRGB)
    You asked me to switch the monitor profile to sRGB, just for the test... no?
    I did that and posted my results.
    The term "first part" refers to my results "before" I switched profiles.
    The term "second part" refers to my results "after" I switched profiles.
    Here, again, are my results after switching to sRGB monitor profile, as you requested.
    >...using sRGB 2.1 as monitor profile for the test you mentioned.
    MonitorRGB and WindowsRGB looked exactly the same, Macintosh is light and washed out. <<br />
    Hope this clarifys for you.
    I am sorry, I am not able to follow your responses to my question.
    First part was BEFORE I switched to sRGB profile for test (Using my Calibrated monitor profile).
    MacintoshRGB goes lighter
    WindowsRGB goes darker
    Monitor RGB goes richer with more saturation, brightness in between the the other 2
    Second part is using sRGB 2.1 as monitor profile for the test you mentioned.
    MonitorRGB and Windows RGB looked exactly the same, Macintosh is light and washed out.
    I have just tried other profiles in the >Displays>Color area. They all produce a shift when "MonitorRGB" is selected. The only one that doesn't is sRGB 2.1
    So I believe this does not prove that my monitor profile is bad. I have been saying this all along, but pleases give me your next thoughts on this.
