  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    You really need to stick to my specific question because I get confused easily.
    >> More saturation and brighter colors in "Monitor RGB"
    Is that the exact saturation problem you are posting about?
    How much change are you seeing?
    (I get a slight saturation boost here, a slight change is expexted.)
    sRGB should not be SoftProofing WindowsRGB darker (it should match or at least be very close to calibrated 2.2 gamma 6500 MonitorRGB).
    >> (With sRGB/MonitorRGB) "WindowsRGB" and "Monitor RGB" look exactly the same! No Color shift at all.
    That's expected since MonitorRGB=WIndowsRGB=sRGB.
    >After calibrating monitor to 2.2 gamma 6500, what happens when you Convert to sRGB in Photoshop and go to View> Proof SetUp: Monitor RGB?
    WHAT KIND OF SHIFT DO YOU SEE?
    I do get a color shift. More saturation and brighter colors in "Monitor RGB"
    Light and washed out in "Macintosh RGB"
    Darker in "Windows RGB"
    >go to System Preferences> Displays> Color and Set sRGB as your monitor profile
    Well, OK... this is interesting. After changing profile to sRGB 2.1, "Macintosh RGB" still goes lighter and washed out.
    Now what? Does this mean that even tho my profile looks great (looks much more accurate than the Apple Calibrator Profile) it's screwed up?
    STILL no direct answer to the question?
    I have to wonder why this post has dragged on 200+ posts and the question has not been answered.
    If you confirm the problem here, go to System Preferences> Displays> Color and Set sRGB as your monitor profile (temporarily for this test to rule out the calibrated monitor profile) then reboot and repeat the above test in Photoshop.
    IF THE PROBLEM IS FIXED, the calibrated monitor profile is bad (you probably have a defective puck/software profiling package).
    If it is not fixed using sRGB as the monitor profile, look for buggy 3rd party drivers you installed, bad hardware or bad system install.
    November 13, 2007
    No prob Nini.
    Nini Tjader
    Buko - I was wrong. It IS Safari 3.0.4 even on my machines. Just didn't see any difference to it...
    Just got the computer back from the Apple store (9:00 pm right now).... I ran it over this afternoon to have them check out the ECC errors I have been noticing. They replaced one of the DIMM risers, it was indeed bad. Now I have to decide if ECC errors have caused any file corruption.
    I had one System Profiler report of 252 errors the other day! So far no errors. I will investigate more in the morning.
    I think the Finder Preview cannot be trusted to display accurately.
    Besides the bug in Column View Preview (which uses the first Alpha Channel to mask the preview, see other posts), the issue is that the Finder uses a form of PDF to generate the preview on the fly.
    Craig
    November 12, 2007
    Nini My Laptop had Safari 2.0.4 on it. After installing Leopard,Safari is 3.0.4. My G5 has the most recent Beta 3.0.3.
    That's how I know. I kept the Laptop with 2.0.4 because of the Forum switch over and 3.0.3 on the G5 gave me a very weird small view of the posts with scroll bars which made it hard to read. So I never upgraded my Safari to 3 on the laptop.
    I win nothing...review this thread and your other thread for the answer...
    Nini Tjader
    Buko,
    no Safari 3.x does not install with Leopard if Safari 3.x is not already present on the machine. If you do a completely new installation on an empty machine with nothing on, you get Safari 2.0.4, nothing else. No 3. You also do not get it if you update an existing machine to Leopard from Tiger. No Safari 3. I've done a couple of both of those last week (for testing purposes) and I assure you that you get Safari 2.0.4.
    Addition: Odd. I doublechecked the Apple website just now about Leopard and it says it comes with Safari 3. Wonder why that does not get installed then... Have to doublecheck my machines at work tomorrow. When I checked them last week I am sure it was Safari 2.0.4. Now I wonder if I saw wrong. I was actually looking specifically on Safari to see if there was something new in it and couldn't find anything and then checked the version. Could the disks in Sweden be different for some reason?
