  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    OK... you win... are these simple steps on your site? Or are you referring to View>Proof Setup> Monitor Profile... because Macintosh RGB is light and unsaturated, Windows RGB is the Darkest, and Monitor RGB is in the Middle but slightly more saturated and actually looks the best... I would prefer it if I could actually use it full time.
    Please point me in the right direction.... I think I have done this previously, but I am certainly willing to revisit the steps you speak of.
    Thanks
    >> We need to think outside the box here.
    Sorry, I work inside the box, but still no answer what happens when my simple steps are followed -- that is the root of the problem and it is where the answer lies.
    >This has been discussed here many times in the past...the simple steps...
    So the fact that the Finder displays a file correctly and an app does not, means I could have a problem with my monitor profile?
    We need to think outside the box here. The monitor profile is fine..... colors look great. I am a graphic designer and photographer, everything looks awesome... except certain apps display of my images... specifically Photoshop's SFW feature.
    Standard test image files we all have seen and used many times (printer_test_file, and olenomoire, etc) look absolutely perfect opened in preview and photoshop with color management. No problems at all.... I even made a profile by hand with Apple Calibrator and had very similar results. Something else is wrong here.
    One other thing I am wondering about is RAM ECC Errors... I have had a few and have replaced some RAM and am still having random ECC errors now and then. Not sure if this could be contributing, or an indicator of something?
    >> I can only assume that no one in this forum has seen this before and therefore has ABSOLUTELY no better idea how to fix this
    This has been discussed here many times in the past...the simple steps outlined are the straightest lines I know to get us on the same page and identify where the problem occurs.
    I do appreciate the time you all have put into helping with this problem.
    I appologize for being sarcastic, as my frustration with this gets the better of me from time to time. I do not know what other avenues to persue in attempting to resolve this.
    Thanks again
    November 12, 2007
    >Safari 3.x does NOT come with Leopard. It is still beta.
    Wrong!
    Leopard comes with Safari 3.0.4 the Beta available for use with Tiger is Safari 3.0.3
    Lundberg02 and Nini - Safari 3.0.4 did come with my install of Leopard. I installed Leopard on a clean disk from scratch. Safari 3.0.4 was part of the install. It's running great and I like it.
    Please look at this image... this is an example of what is going wrong with my system.
    In this un-altered screen grab, you will notice that in the Finder preview (looks awesome) and in the QT Player (looks like crap) the SAME EXACT FILE appears different in the SAME EXACT screen grab. Nothing wrong with the monitor profile, something wrong with how the system displays images. Since I have now demonstrated this to be a system-wide issue, I can only assume that no one in this forum has seen this before and therefore has ABSOLUTELY no better idea how to fix this than a complete idiot like myself. Perhaps I should spray some Windex on the power cord
    Screen Grab
    Nini Tjader
    When the monitor displays the same exact image, 2 different ways, at the exact same time and they look completely different, how can that indicate a monitor profile problem? Makes absolutely no sense to me.
