  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    >> root of my Photoshop troubles
    I outlined some very specifice steps to troubleshoot the problem in Photoshop, including how to rule out the monitor profile.
    Yes, I use Adobe Ace in Photoshop. I'm wondering if Color Sync, system wide, is affecting things somehow. Maybe my OS X has a corrupt color sync file. Something is managing the color of the finder and QuickTime Player and getting it very wrong. This might be the root of my Photoshop troubles. May not be Photoshop at all!
    Ramón G Castañeda
    Peter,
    >or might this somehow still be a color sync issue?
    I don't remember if we have discussed this already in this long thread, but you should NOT be using ColorSync at all, ever. Make sure you are set to ACE (Adobe Color Engine) not ColorSync (which is Apple color engine).
    I can't comment on your QT video, since I don't deal with video. :|
    Would I be premature in assuming that something in my system is corrupted, or might this somehow still be a color sync issue? Does the Finder use color management?
    November 12, 2007
    Hmmm now that is really noticeable
    I am begining to suspect that something else may be wrong with my computer/Video Card.
    Below is a link to a screen capture showing a Finder Preview (column view), and the actual QT movie opened in QT Player. How can these 2 images of the exact same file appear so different in the same screen capture??
    This is exactly the same type of affect I am getting in Photoshop SFW (Loss of saturation). Coincidence, or indication of some other, system-wide problem?
    Input please!
    Finder View
    November 12, 2007
    Leopard.
    Larryr544: Where did you find Safari 3.0.4? Did it come with Leopard? It is not available at Apple Downloads, which implies that it is Leopard only.
    monitor
    Ramón G Castañeda
    >Which it was intended to do.
    Yeah, in black and white
