  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    >>1.8
    You mean monitor gamma or source/document gamma?
    1.8 saves me a lot of time trying to get pictures on copy paper to look like the monitor. Which it was intended to do.
    November 9, 2007
    Well you know that the 1.8 gamma is a holdover from the Apple laserwriter days. That's the only way they could get it to print correct.
    read this. http://docs.info.apple.com/article.html?artnum=302827
    Quote from the page:
    >During the calibration of your display, you will need to choose gamma and white point settings. The correct choice depends on how you are most likely to use your images. The best rule of thumb is this:
    > Unless you have a color management expert instructing you otherwise, select a 2.2 gamma and a D65 white point.
    so even Apple recommends a gamma of 2.2
    Unless you can explain why I need 2.2, no thanks.
    I used Supercal to trim my LCD colors and got beautiful rich blacks as well.
    I want my monitor to look good to ME.
    I use Safari for all web images, so I get whatever was in the image.
    And I certainly respect your every word. Unless you say "Microsoft".
    November 7, 2007
    Lundy calibrate your monitor with a Gamma of 2.2 and let the calibrator use the monitors whitepoint then you won't have yellow whites.
    <Raven Plenty - 12:20pm Nov 7, 07 PST (#182 of 184) <br />Peter, yes I know Firefox is not color managed. I make the case that my colour will be unpredictable on other peoples screens regardless of how well I understand colour management, due to the infinite variety of monitor qualities and settings. If I am happy with the way web pages appear on my screen, and I can create graphics that look good (and are as I wanted them to appear) in a browser on my screen, well that's all that any of us can do really. ><br /><br />I set up my LCD at 1.8 and 9300 for two reasons. 1. I can't stand yellow whites 2. LCD 3/4 tones and below are brown in 6500 3. It's easier to get a print that matches the screen on Staples cheapo copy paper. OK, that's three reasons. I don't need to be consistent because nothing else is.<br /><br />If I like it I don't give a rat's patootie what it looks like to Mrs Joe Sixpack's PC AT.<br /><br />Color management is lunacy in a world of consumer PCs. For print, obey every word of Buko, Mike, g, Jeff, and Peter Figen, especially the latter.
    November 7, 2007
    Over all I think this was a pretty good thread and I've increased my knowledge in the world of Photoshop Color management. That's not really saying much, I never had a handle on it in the first place... Thanks all!
    November 7, 2007
    g ballard,
    Here is where I am still confused: What you are saying, as I understand (or misunderstand) is that if an sRGB tagged image looks different in SFW with "convert to sRGB" checked, then my monitor profile is bad. Or put another way, any difference I see is the difference between my monitor profile and the sRGB space.
    I'll leave it at that for now...your thoughts?
    November 7, 2007
    Thank God for collecting bits and pieces from every facet of all industries to create the most comprehensive half baked feature and releasing it to see what happens with no regard to whom is affects.
