  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    Ramón G Castañeda
    G B,
    >This makes my point that unmanageable html page color, untagged graphics, and tagged sRGB in color-managed browsers is mixing apples with oranges...
    Point well taken.
    November 7, 2007
    g & Peter, that's what I see also in both Safari and Firefox.
    Raven, firefox is not colour managed and will not show the differences. In a non-colour managed browser, they will turn out as you described. In a colour-managed one like Safari on the Mac, BCE look similar to me, A and D are a bit redder, and G looks like a darker brownish colour. Dirk probably started making his colour out of different colour spaces and then converted (or not) and posted the images without a profile (I think one had the profile in it).
    This shows the importance of colour spaces and knowing what you're doing. If you don't, your colour will be unpredictable on other's screens. Using your monitor profile for your images means that it will only look good for you, and for others, it will be a toss-up depending on how well your monitor is calibrated.
    So F and G are the same file -- sRGB -- except F is untagged sRGB and G is tagged sRGB.
    In SAFARI:
    The page color and untagged srgb (F) are both having the monitor profile applied/assigned/assumed so they match -- they are being treated the same. G is honoring the embedded profile and Converting to Monitor RGB so it is different.
    In FIREFOX:
    F&G are both sRGB (FF doesn't see G's profile) so the page, F and G all are being treated the same and therefore they match.
    November 7, 2007
    How I did "F" was that I went into Edit> Color Settings and set the Working Space from Adobe RGB (1998) to sRGB IEC61966-2.1... A thru E were set at Adobe RGB (1998). Also on the "F", the original image was an Untagged RGB. When I went to SFW I unchecked the "Convert to sRGB. "G" is the same except I checked "Convert to sRGB".
    sRGB profile colorspace is a common standard colorspace for monitors.
    >> what's the point in calibrating then?
    BECAUSE in order for Photoshop, color-managed applications, to display color accurately, the monitor needs a good calibrated profile to tell it HOW to paint the colors on screen.
    For now, this is all I have....May I suggest reading anything by Bruce Fraser, especially Real World Color Management (Paperback) by Bruce Fraser (Author), Fred Bunting (Author), Chris Murphy (Author)
    November 7, 2007
    Dirk, to my naked eye, A thru E look identical and are brighter than the background. F & G match the background exactly.
    Viewed in latest Firefox and using my calibrated monitor profile.
    F is the closest in Safari.
    November 7, 2007
    g ballard, I'm interested in trying your sRGB monitor profile test. Would you recommend "sRGB Profile" or "sRGB IEC61966-2.1"?
    One thing that confuses me here is that you seem to be suggesting that a monitor profile that is different than sRGB will yield bad results in PS, or in SFW anyway. But what's the point in calibrating then? sRGB is an unacceptable monitor profile for me to use for print work. I believe this is the missing link in my comprehension of color management.
    Meanwhile...I've come to agree that I shouldn't use Monitor RGB as my working profile or as an embedded profile in my image files. (I still prefer Adobe RGB as the best color space for making adjustment and colour corrections.) But I think I should be converting to Monitor RGB before using SFW. That's the only way I know of on my system to get a browser-displayed JPG that looks the same as my PS file. I can't control what it looks like on other monitors of course, but I can only control what I can control.
    F (which is untagged, likely untagged sRGB?)
    Which one is tagged sRGB?
