  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    November 7, 2007
    "If you set a html page color to 8a4545"
    Okay, which one of these boxes match the background? 8a4545 test
    I think for most users the short answer is:
    1) Calibrate monitor to 2.2 gamma, D65/6500.
    2) Convert Photoshop color to sRGB before Save For Web (manually or by CS3 default).
    3) Do not check ICC Profile option (strip the profile).
    4) Use High or higher JPEG setting.
    If you get an unnatural shift between untagged sRGB and tagged sRGB in Safari, your monitor profile is likely the problem.
    Or in Photoshop with an sRGB file, if you get an unnatural shift in View> Proof Setup> Monitor RGB, your monitor profile is likely the problem.
    To rule out the monitor profile, go into System Preferences> Displays> Color and set sRGB for the monitor profile, reboot, and retest.
    If the problem persists using sRGB as the Monitor RGB, then test in a new user account (your install or hardware is flaky). Defective calibration pucks/software are notorious for causing these kinds of color issues. Setting a canned sRGB profile will rule out the puck.
    Lastly,
    Working in SoftProof mode (View> Proof Setup> Monitor RGB) for web work is only confusing and slowing you up. Photoshop is already displaying sRGB accurately if we have a good monitor profile (and the calibrated monitor space is unique) -- which is my point.
    Tagging web images:
    If you set a html page color to 8a4545 (for example), and fill a Photoshop box with 8a4545 and SFW with sRGB embedded profile -- does the box match/blend in with the page in managed web browsers like Safari?
    The page color is unmanaged, applying MonitorRGB, the JPEG is Managed, applying sRGB so I don't think they would match.
    If you slice a JPEG in 10 pieces, does that add 10 more profiles to the page.
    I know adding 10 more tagged JPEGS will add on 10 more profiles to the page.
    If you add each logo, graphic with embedded profiles on top of that, the profiles are bloating the page with data.
    My point is I don't think embedding profiles in web images is a good idea for most users.
    Embedding one profile in a web page IS a good idea, but that doesn't work yet...
    Ramón G Castañeda
    Larry,
    >then whether 'Proof Colors' is on or off is involved in the CS3 printing issue?
    YES; but that's a different issue. The soft proof profile should NOT affect printing, but it DOES in this version of Photoshop 10 because the Polaschek team managed to mess up the printing engine.
    But you also have to set it in the Photoshop PRINT dialog box:
    Ramón G Castañeda, "Printing: The infamous TechNote ID: kb400878 is a major screw-up!" #5, 8 May 2007 8:41 pm
    We have gone over this several times before.
    > I should have it on and set to my target printer paper when I'm looking to print an image?
    YES, absolutely, of course! Otherwise you don't know what it's going to look like in print and cannot make appropriate corrections.
    You really, really should buy the Schewe "From Camera To Print - Fine Art Printing Tutorial" video tutorials:
    http://www.luminous-landscape.com/ (scroll down a bit)
    Ramon - Concerning your post 154. Then whether 'Proof Colors' is on or off is involved in the CS3 printing issue? I should have it on and set to my target printer paper when I'm looking to print an image?
    I agree with MO this is all getting out of hand and overly complex.
    Let's do a group confession to Adobe and ask for compassion so that we can be forgiven and they will give us back the ability to get anything out of Photoshop. That is Photoshop is designed to create images that usually are printed or shown on the web. Even the Bridge slide show is hosed. So the program is essentially hosed. There is virtually nothing working as far as output from Photoshop. Am I overreacting???
    Ramón G Castañeda
    I left my virtues in the confessional...
    bless me Father for I have sinned.
    Ramón G Castañeda
    Yep, that's an admirable virtue, Mike.
    Oh - piss Jeffy off?
    ;o)
    big deal....
    The whole problem is all of us retards (everyone) needs to get along one day and learn a simple thing called tolerance.
    Ramón G Castañeda
    LOL @ Mike!
    It looks like after the incident with John Nack, picked up by a respected photo and Photoshop guru we all know and whose book on ACR we eagerly await, I've been put on Adobe's black list.
    If I tried to lobby Adobe to listen to you, it would be counter productive.
