  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    >I like to refer to people who hand me untagged files as morons who deserve to be beaten with a baseball bat.
    Then lobby Adobe to F-ing listen to me and change the retarded way we manage color.
    OK... I guess that's the best way then... profiles, death and taxes... I like that.
    Ramón G Castañeda
    I agree with Mike: keep the embedded profile.
    Ramón G Castañeda
    >since most viewers are on PC's
    with uncalibrated monitors.
    No matter what you choose, Windows Color, sRGB, Monitor RGB, you still have no idea what your image will look like to any individual viewer.
    Only viewers using Safari and an accurately profiled monitor will see exactly what you see if you embed the profile in your web images, which, incidentally adds only about 4 KB to the size of your file. Otherwise, don't sweat it.
    At this time - my opinion is to convert to sRGB because it's a linear color space. Monitors are not such animal and considering that a majority of web images are used for multi-purpose, the file will represent what you intended to hopefully more people then less. People should stop discarding profiles in RGB images PERIOD. aka this mess of a thread.
    Look at the image in sRGB "tagged image". Set your working space to sRGB for untagged images. Convert in SFW to sRGB - regardless of what the image's color space is. Embed the profile. Stop paying taxes.
    So, since most viewers are on PC's... we should select Windows Color?
    Ramón G Castañeda
    >What is the significance of 'Proof Colors' being on or off?
    When it's on, you get a much better idea of what your image will look like in the end on the intended device, which in the case of web images boils down mostly to the viewer's monitor.
    Ramón G Castañeda
    FWIW, my position is that Proof should be set to whatever your final output device is. For web I would use Monitor RGB (for the gazillion uncalibrated, non-color-managed users that make up 95% or so of web viewers) or sRGB if I'm going to embed the sRGB profile in the file.
    Peter (or anyone else) - Are you then suggesting that Proof Setup be set to sRGB or???
    Thanks!
    Raven,
    Don't convert to Monitor RGB. Convert to sRGB. You will only end up confusing things more if you use Monitor RGB as an actual working space. I only talked about using it for troubleshooting. You have to understand WHY to use in order to actually do it and not pay for it later.
