  • October 31, 2007
  • 680 replies
  • 62256 views
Pete
    November 7, 2007
    I hope what works for me works for you as well Peter. I also have a tendency to obsess about things until I have totally got it sorted out.
    It occurs to me that rather than using Monitor RGB as a Proof Setup, I could get the same results by using Monitor RGB as the embedded profile for my web image files...thereby making it "stick" between sessions, instead of me remembering to turn on "Proof Colors" each time I open a web image.
    Or, I can use any embedded profile -- I just need to remember to convert to Monitor RGB profile when it comes time to SFW.
    By George I think I'm on to something here.
    November 7, 2007
    I just played around a bit.
    Adobe RGB goes straight to SFW uncompensated bit of a slight difference, not much.
    Adobe RGB converted to sRGB goes to SFW uncompensated practically identical. Quality was 20.
    Exactly~!
    1. View Menu > Proof Setup > Monitor RGB.
    2. Make sure Proof Colors is turned on (Cmd+Y to toggle) while making image adjustments.
    3. Make sure "convert to sRGB" is NOT checked in the SFW menu; that "Uncompensated Color" is selected in the preview window menu; and that "ICC Profile" is unchecked.
    Thanks for your helpfulness... I for one appreciate your tenacity in this matter. I will try this suggestion. I have to admit that I am by now a bit exhausted with all of this and have basically given up. There is definitely something wrong here. It's not my imagination, and it's not my monitor or it's calibration. I will admit that I am a perfectionist and these things tend to drive me crazy until find a solution. For my own sanity I am now using PS 7 for web work as it just seems to work. I am sticking with OS X 10.4 until a solution is found as 10.5 is not compatible with PS 7. I will look into your suggestion. Thanks again!
    November 6, 2007
    For anyone who is still frustrated by SFW behaviour, here's what is working for me:
    This gives me a JPG in a web browser (on my computer) that looks the same as the original image in Photoshop WITH "PROOF COLORS" TURNED ON. That's the best I can do, but it's acceptable for my primarily print-oriented work. (I only wish that saving a file would remember to use "Proof Colors" when I open it again, so I could apply it permanently to my web-oriented images.)
    November 6, 2007
    I think I'm sort of understanding some of this. Perhaps every monitor I've used up until now has been closer to sRGB, including the Apple Cinema Displays, which I calibrated only by using the Display Preferences calibration tool, and then only switching gamma to 2.2 and white space to D65.
    I look forward to seeing how my calibrated set up looks compared to reliable printer's proofs. If it looks ok then I'll know that my CMYK set up is good.
    1
    >Does that makes sense to anybody,
    yes - Photoshop is not compensating your preview routed to the video card until you close that dialog box.
    2
    Sound like your monitor is close to Adobe RGB color space and not
    sRGB.
    November 6, 2007
    Although I have figured out a way for me to get the result I want using SFW, there are a couple of questions I would love to have answered:
    1. When I am clicking on different monitor profiles in Display Preferences, I see a live change each time I click on a different profile. However, as soon as I actually close the Display Preferences dialog box, the Photoshop image I am viewing (and only the PS image, nothing else on the screen) changes drastically again to something completely different. (I'm not sure at this point if the end result is actually accurate...we need some accurate colour proofs from a printer to use as a reference). Does that makes sense to anybody, that Photoshop is re-adjusting after I close the Display Preferences window?
    2. In CS2 and earlier, I had to remember to convert to sRGB before using SFW. (eg. an Adobe RGB image taken into SFW loses saturation, but an sRGB image looks identical in SFW.) However, in CS3 now when I take an sRGB image into SFW, the colour becomes more saturated, no matter if "convert to sRGB" is checked or not. An Adobe RGB image looks the same in SFW if I have unchecked "convert to sRGB". This all seems backwards. Why would an sRGB image change when taken into SFW?
    November 6, 2007
    Peter Figen, just to confirm...you are taking an Adobe RGB image into SFW, with "convert to sRGB" checked, and it looks the same? Does your resulting image when viewed in a browser look the same as your Adobe RGB image in PS?
    yep G.
    I have become very rich because Adobe has not listened to me.
    Life is good.
    Maybe they should smoke that for a while.
    ;o)
