  • October 31, 2007
  • 680 replies
  • 62138 views
Pete
    The only way I would believe there's a problem with CS3 default Save For Web Settings hosing normal-gamut color with "high" quality jpeg compression is to post the tagged and untagged sRGB files in a rollover on a black page so they can be viewed in Safari through a monitor profile I trust -- seeing is believing...
    Ramón G Castañeda
    Lundberg02,
    Either your copy of Safari or your naked eye is off. :)
    Using Safari 2.0.4 (current non-beta version) I can definitely see the subtle differences the posters are complaining about. The differences range from barely perceptible to in-your-face different, depending on the compression used by the posters. If I were working on the web (which I'm not) I might be puzzled too.
    But Buko is right, none of those differences amount to a hill of beans in the light of the 95% or more of the web viewers using non-calibrated, non-profiled monitors anyway.
    welcome.
    Safari is colormanaged. All the pictures that have been posted look exactly the same to the Mac/Safari calibrated LCD naked eye.
    Ramón G Castañeda
    MO,
    > The small color difference you are seeing is in the preview because of the rounding of numbers due to the fact that its going through two color space conversions "visually."
    > Same thing happens for Proof set-up.
    Thanks for that insight, Mike.
    "Do all the pictures you post in the PS forum look exactly the same in Safari?"
    Yep... and the really amazing thing is that Safari is able to show the difference between the 2 images in that single screen grab, and doesn't somehow make them appear identical by figuring out how to use 2 separate profiles at the same time!
    Is there a setting for that? ;-)
    November 3, 2007
    Also the level of compression will change how the image looks so if you are making small files for a fast load they will never look identical to the original.
    In fact if you take Ryan's image in #74 and lay one over the other and do a difference the difference is quite small. The SFW has better blacks and the rest of the 'difference' looks basically like JPG noise. While I have seen problems with CS3 SFW this doesn't seem to be an example.
    November 2, 2007
    The whole point of Save For Web is to make the smallest file possible to upload to your website so that the person visiting your website doesn't get bored waiting for your page to load and click off to another faster loading site.
    So to get this smaller file SFW strips off all the unnecessary data like profiles, comments, metadata, thumnails and whatever else that will bulk up a file.
    That and the fact that very few browsers are colormanaged (using your monitor profile to display the image). So what might be blue on your monitor will look purple on the next !0,000 monitors because not only are they viewing through non-colormanaged browsers they don't even have calibrated monitors.
    The differences are so small that you guys are making mountains out of molehills.
