  • October 31, 2007
  • 680 replies
  • 62138 views
Pete
    >Now what? Oh god let it end...
    Save as dialog box
    November 2, 2007
    Well then, since I am taking an sRGB image, using SFW with "convert to sRGB" checked, and the resulting image as seen within the SFW dialog box is drastically different in both the "original" and "JPG" panes, then something is wrong.
    >How is the tag stripped?
    Save for web removes or strips the ICC profile upon export in some cases.
    >And isn't the "convert to sRGB" checkbox converting it?
    yes, and removing the profile in some cases.
    The problem is the confusion between original and optomized settings in the tabs of the image for SFW.
    November 2, 2007
    How is the tag stripped? And isn't the "convert to sRGB" checkbox converting it?
    >Seriously though...if an sRGB tagged image is changing when I use Save For Web, is not something wrong?
    If the tag is stripped and the image is converted upon export then yes.
    November 2, 2007
    By the way, for all you Dell haters out there, it was not my decision to make.
    November 2, 2007
    Mike...you assume I understand what the heck you're saying. I'm sorry, that just didn't shed any light on this for me. Thanks though, I guess?
    Lundberg02...the ROFL people?
    And I'm still wondering why different Display Preferences monitor profiles have such a dramatic effect on the way that SFW works. I really appreciate the talent and skill that some of you have to offer here -- g ballard and Mike Ornellas, you both seem to have a thorough understanding of how this all works -- but something is getting lost in translation.
    Although I really would like to gain a thorough understanding of colour profiles, I am prepared to just forget the whole thing...I just want Save For Web to work the way it used to for me. If a certain set of PS SFW settings result in no colour shifting during the process, then why should it change so much depending on the System Preferences monitor profile? As per my earlier comment (#90) about the System monitor profiles affecting the display globally.
    Two guys go into a bar. The bartender says, "Are you both using a Dell LCD monitor?'
    "Yes"
    "Do all the pictures you post in the PS forum look exactly the same in Safari?"
    "That's what the ROFL people are saying"
    you are assuming linear color spaces between the two devices. This is your first mistake.
    you assume that the capture is being converted to a working space.
    you assume that the image may just be getting dumped into the working space with no conversion.
    November 2, 2007
    This may be too tangential, but one thing I've never understood:
    Adobe RGB (1998) is supposed to have a wider gamut than sRGB. But in both cases, in 8-bit images each channel (Red, Green and Blue) have values ranging from 0-255. Where is the extra colour range coming from?
    I can understand output devices having different gamut. We just replaced an old Sony CRT with a new Dell LCD. The Dell has drastically increased contrast. So if I displayed an image on the Sony which included pure black and pure white, I could recreate that appearance on the Dell monitor, and still be able to go beyond that to darker blacks and brighter whites. So what's the difference between Adobe RGB and sRGB when a camera or a scanner is capturing an 8-bit image?
