  • October 31, 2007
  • 680 replies
  • 62138 views
Pete
    November 2, 2007
    Ramón, I'm either not understanding you or you're not quite right. If I create a monitor profile that is waaaay of, super dark and bright orange say, then everything displayed, including Photoshop, Word, and Finder windows, are super dark and orange.
    Ramón G Castañeda
    Raven,
    Just remember that non-color managed applications, like Word and most other applications, do not use your monitor profile like Photoshop does.
    Ramón G Castañeda
    Ryan,
    One can only hope you get a response any type of response. :/
    Ramón G Castañeda -
    I took your advice and contacted Adobe support.
    I'll be patiently awaiting their email.
    Hopefully they won't give me a "Quark-like" type of response. :)
    November 2, 2007
    Thanks for the clear testing instructions in post 78 g ballard. I tried them all, including creating a new User. I still saw on obvious shift in all three cases, including taking an sRGB tagged image into SFW, which shouldn't show any change at all, right? Gah.
    My question remains...should system-wide monitor profiles even be causing colour differences between PS image display and its SFW display? I still feel like the system-wide monitor profiles should affect everything equally, and function separately from Photoshop's colour management.
    My successful setup in the past has been using a recent iMac, and therefore Apple Cinema Display, with the installed Apple Cinema Display monitor profile selected, but shifted to 2.2 Gamma. That was fine. Perhaps since I hadn't used any other setup in the past, I haven't known until now that Adobe will operate quite differently depending on the monitor profile, rather than the monitor profile simply acting as a "filter" on top of all display element. eg. If the monitor profile creates a greenish cast, then everything will have a greenish cast whether it's a Word document, a web page, or a Photoshop file viewed normally or in SFW. Am I wrong?
    I just tried the suggestion of create new user and try this again.
    All my photoshop settings under the new user appear to be the same, except it defaults to North American Prepress General Purpose 2 (with unchecked "Ask when opening" boxes being the only difference). I left it set "as is" Here are the 4 different colors I get when trying Uncompensated Color, Standard Mac, Standard Windows, and Use documents Profile. With the default "Convert to sRGB" checked. All within the SFW window.
    Hopefully everyone can see the difference in color, it is quite noticable on my full screen.
    "Standard Windows Color" is the only one that gives the correct appearance. What does this mean?
    Uncompensated Color
    Macintosh Color
    Windows Color
    November 2, 2007
    I have a question... If you covert your PSD file to sRGB (Convert to Profile: sRGB IEC1966-2.1), before going to SFW. Then go to SFW and check the ICC Profile. Isn't it doing a double sRGB profile? Because if I do that and save, the image is a little saturated but if I don't check on the ICC Profile button and save, the jpeg file looks like the PSD with no shift.
    They are actually the same test (both strip the sRGB profile and apply the monitor profile) and should display identical results.
    "a little bit of a shift" here is normal and represents the difference between the sRGB profile and the Monitor profile.
    At this point SFW appears to be working for you, or not?
    November 2, 2007
    "Free revolver with every upgrade."
    I already have that Beatles CD. Can I pick something else from the fruit basket Blind
    November 2, 2007
    When I did the first part of the test in the "SFW", I see no shifting at all... but when I do the "Proof Setup: Monitor RGB" test, I see a little bit of a shift. What does it mean if one part of the test it works fine but the other is off a bit?
