  • October 31, 2007
  • 680 replies
  • 62138 views
Pete
    October 31, 2007
    >using untagged sRGB
    If its untagged how can it be sRGB?
    > just figured that the dell is so much sharper and richer that it shows the problem more betterer...
    Just because a monitor is over saturated or overly sharp does not mean its better. I would think someone using a Dell is doing so because they can't afford an Apple or an Ezio. I would not put Dell and Quality in the same category. Also the huey is not the best calibrator either. The Huey has been the cause of many a color profile issue discussed in the Color Management Forum. This is another product that Is cheap.
    "use embedded profile" causes PS CS3 to honor the embedded profile (always choose this when a mismatch is detected) then go to "Convert Profile" for a smooth conversion. I have done this... no problem so far. PS is not stripping the profile, it is honoring it. I just read all this at your site I believe. Then I convert to sRGB in preparation for SFW. That's where the problem is... the conversion to sRGB... it is not doing this properly... IMO.
    Proof setup > monitor RGB looks fine in Adobe RGB but not in sRGB, after the conversion.
    I am not stripping the AdobeRGB profile... I am converting it to sRGB.
    How would you suggest converting it to sRGB before SFW?
    Of course I am using Adobe ACE, and I am using CS3
    >> First of all... I'm using an Adobe RGB image master... I open it and get the Profile Mismatch Screen... I choose Use Enbedded profile... all looks well. Next I go to Proof Setup > Monitor RGB... again all looks well, no change that I can tell.
    This has further confused the issue on several points, not the least of which version PS you are doing this with?
    >> AdobeRGB> Convert to Profile > Working Space sRGB-2.1... all still looks well... but now, when I go to Proof Setup > Monitor RGB... I see the insane oversaturated look that is driving me nuts.
    That is your strongest clue...it sounds like you have a bad system or bad monitor profile. To rule out the monitor profile: Set sRGB as your monitor profile in System Prefs> Displays> Color.
    That doesn't make sense, stripping an embedded AdobeRGB profile should desaturate the color in Softproof MonitorRGB, especially the reds -- you have something wacky going on there.
    At this point I think you need to review the links and get a grip about how color management and profiles work...
    BTW, forget about setting ColorSync in PS COlor Settings, use Adobe ACE.
    MO,
    I think SFW is fixed under CS3 :) By default it Converts to sRGB and strips the profile.
    Some web browsers will honor profiles, and some don't.
    Yes, and all assume sRGB unless told otherwise... so why the problem when using untagged sRGB... it is sRGB after all. Unless there are different sRGB profiles... could that be a possibility? Is Photoshop assigning the wrong sRGB profile?
    How could the Dell monitor be causing this... in conjunction with the profile? Any ideas how I could test this theory without buying a different monitor? My old Sony Multiscan 500PS is too tired these days, but does show some of the same color shifting. Perhaps I should disable the monitor profile and/or make a new one using the built-in apple eye-ball calibrator?
    I just figured that the dell is so much sharper and richer that it shows the problem more betterer... Thoughts?
    > Why does an untagged sRGB image display different in a browser, than a tagged sRGB image?
    Save for web is broken and will continue to be broken until fixed.
    The file is not fundamentally broken unless you are breaking it.
    October 31, 2007
    I work in Adobe RGB and let SFW convert. I don't see a problem.
    It just may be that Dell monitor you are using. in conjunction with the calibrator.
    Is there something fundamentally wrong with the file?
    I have been converting to sRGB before going to SFW, but I have the Convert to sRGB checked anyway. I figure it couldn't hurt.
    I am suspecting that converting to sRGB is not working properly. Monitor proofing looks fine unless I have converted to sRGB..... weird.
    October 31, 2007
    I'm getting something different. When I go to SFW and uncheck the "Convert to sRGB" option, the jpeg image look very very close to the original PSD image. What is that saying?
