  • October 31, 2007
  • 680 replies
  • 62138 views
Pete
    Ramón G Castañeda
    Larry's post is further food for thought;
    >For me it's intermittent. And I've never figured out what makes it work and work breaks it. I just try to use it when it's working!
    Ramón G Castañeda
    In my case, it was most likely user error.
    For one, I did not realize that the flyout menu in the SFW&D dialog (where you selected Use Document Color, Uncompensated Color, etc) applies separately and individually to each of the two or four windows when you use 2-Up or 4-Up view. Setting one does not affect the other one(s), and they can individually and seemingly capriciously set themselves to different value.
    Second, I've been able to recreate some of the weirdness I saw only by taking a tagged 16-bit image file in ProPhoto RGB and leaving Uncompensated Color selected. I'll play with it some more tomorrow.
    Mike - This happened to me in my early testing of SFW. At first nothing worked right. Then it did. For me it's intermittent. And I've never figured out what makes it work and work breaks it. I just try to use it when it's working!!
    I had a blast doing trick or treat this evening. My 4 year old loved it.
    Cleaned out -with about 500 or so guests in the Bay Area in our hood.
    ;o)
    Ramón G Castañeda
    Well, I take it back.
    I hereby withdraw all my comments in #14, 43 and 44.
    In the last two hours I've been doing nothing but continuing to test this and answer the door to give treats to little goblins, monsters, witches, pirates and princesses and I have not been able to replicate any of the extremely weird issues I was seeing in Save For Web last night and earlier today.
    I'll continue testing to see if I can duplicate whatever conditions made it go crazy earlier.
    For the past two hours, all functions of Save For Web are acting correctly, as they should.
    If I manage to see the issues again, I'll report back. Otherwise, I'll just go sit in the corner.
    >MO,
    I think SFW is fixed under CS3 By default it Converts to sRGB and strips the profile.
    It's only partially fixed. aka - still not functioning correctly to make it seamless and function as expected.
    Ramón G Castañeda
    If I don't use uncompensated color and view the Original tab, the original looks miserably, sickly green.
    Ramón G Castañeda
    MO and Peter appear very likely to be right: Save For Web is messed up.
    Just try the 4-up view. (!!! %() You'll get at least one of those views with absurdly wrong colors.
    The reason I hadn't noticed it is because I always use the Optimized view ("one-up") and Uncompensated Color, in which case everything works OK, and I very seldom use JPEGs anyway.
    The dell monitor is not creating colors where there are none.
    I have stated that my G4 with Sony Multiscan500PS also shows a color shift... more saturation to be exact... just not as noticable. The difference is that the sony crt is not capable of more saturation. The Dell is revealing the increased saturation because it can... not because it is better. The Sony CRT is not revealing the full saturation increase because it cannot.
    Photoshop is changing my files and I do not want it to. All I am trying to do is discover why this is so.
    Besides more people are browsing the web with simple, basic LCD screens... if I see it, they will see it too. Perhaps your screen is incapable of seeing the difference in the images I have posted? Either way... only my SFW jpg photos look like crap... my general PS working screen is just fine.
    I will investigate the HUEYPro for issues, anything is possible I guess.
    I just don't understand why it is so difficult to communicate the problem I am having. I cannot save JPG's from photoshop with CS3
    Here is an image I made in CS1 that displays perfectly in ANY browser... why?
    Please try it yourself... If you have the answer, please let me know.
    It is an untagged RGB file with SFW in CS1
    http://www.hostzombie.com/cs3/test.jpg
    [large image replaced with its link]
    November 1, 2007
    "I would think someone using a Dell is doing so because they can't afford an Apple"
    No, I ordered the 23" Cinema Display and it showed up at my door with a dead pixel right in the middle of the screen. I'm not paying $1000.00 for a monitor with a dead pixel.
