  • October 31, 2007
  • 680 replies
  • 62138 views
Pete
    SFW is working fine here.
    I pointed you directly to the problem: PS> (Convert to sRGB) View> Proof Setup: Monitor RGB
    AND, I outlined above HOW to rule out the monitor profile...
    Maybe people should not use SFW.
    Well I am glad to see that you all are taking me seriously on this matter. I was beginning to feel like a terrorist... all I wanted was some love and affection ;-)
    I do not have a clue as to what is causing this on my end, but it is not intermittent for me.
    At this point I will be happy if I can SFW with ANY combination of settings, no matter how complicated or unintuitive and since I am not a colorist or professional profiler or photoshop guru, I will retreat somewhat and hope to DOG that someone figures this out, or comes up with a new direction to look. I need to get some work done before the wife leaves me!
    For now, I will fudge the color and hope for the best. Maybe I should just re-install CS1 on another machine.
    Peter
    November 1, 2007
    "close enough for government" workaround"
    I don't see that as a workaround. Just send some time surfing many of the photography websites and download some images. You will see a lot of them tagged, "Untagged RGB" rather than "sRGB". It's easy to do when you go to SFW, just uncheck the "Convert to sRGB". If you go to g ballard's website, and lownload his images, you will see they are untagged RGB.
    >> I figure it shouldn't matter what colour profile is used, the original image should look (almost exactly) the same as the SFW image if "convert to sRGB" is selected.
    In CS3 Save FOr Web that should be the case, any difference being the difference between sRGB and MonitorRGB.
    There are ways to screw up the default SFW settings and confuse the issue, though...
    November 1, 2007
    We just got new Dell 24" monitors here at work, and I am experiencing the same issue as Peter. I haven't worked here for very long, and we don't really save for web generally (I haven't yet), but I have an enquiring mind.
    I am wondering if this problem only exists for people using calibration software...in my case, Spyder Pro 2. It doesn't seem logical to me though, since I figure it shouldn't matter what colour profile is used, the original image should look (almost exactly) the same as the SFW image if "convert to sRGB" is selected. PS isn't using different monitor profiles for different processes, is it?
    Unfortunately I'm not very familiar with my Save For Web behaviour before switching monitors. I will reconnect my old monitor and see what can be seen. Meanwhile, we do know that both Peter and I are using the same Dell monitor and have used calibration software, albeit different brands.
    I'd rather find a way to make things work as they are supposed to, instead of finding a "close enough for government" workaround.
    Hmmm, and grrrrr, and stuff like that.
    Ramón G Castañeda
    >I can live with this.
    So can I. I don't generally deal with the web anyway, just the occasional JPEG uploaded to Pixentral to illustrate a point, as I did above.
    November 1, 2007
    Cool trick!... I'm getting the same results as you did. Close enough for me. I can live with this. Thanks :-)
    Side note: I calibrated my monitor with the Spyder2 Pro.
    Ramón G Castañeda
    &gt;Does anybody see any difference? <br /> <br /> Sure. <br /> <br /> You can confirm that by dragging one on top of the other in Photoshop and setting the blending mode of the top layer to Difference. If there were no differences, you'd expect to see a solid black rectangle. Instead, you get this: <br /> <br />c <a href="http://www.pixentral.com/show.php?picture=1MfEGPWjcbGjYOcX1lAapBNqZWNeJ0" /></a> <img alt="Picture hosted by Pixentral" src="http://www.pixentral.com/hosted/1MfEGPWjcbGjYOcX1lAapBNqZWNeJ0_thumb.jpg" border="0" /> <br /> <br />Close enough for government work? You decide. :)
    November 1, 2007
    I calibrated my monitor to 2.2/6500. Opened an image that had an embedded profile in Adobe RGB (1998). I did not convert the image before going to SFW. Went to SFW and saved the first image as untagged RGB. then again sRGB. Both images are on this <a href="http://www.apo442.com/sfw/test.htm">web page.</a> They both look the same to me. Does anybody see any difference? I opened the original PSD image on my calibrated monitor and put it side by side with the web page with the two images. I can see <B>no</B> difference between any of the three. So does this mean I nailed it? Or did I just get lucky? <harrycallahan>Well, do ya, punk?</hc> <img src='http://www.adobeforums.com/Images/e/grin.gif' alt='Blind' border=0>
