  • October 31, 2007
  • 680 replies
  • 62290 views
Pete
    ok so it would be like this:
    1) duplicate the original twice and then close the master;
    2 convert both copy to sRGB;
    2) use one as reference;
    3) setup a soft proof on the second picking up your monitor profile as Device to Simulate and make sure the "Preserve RGB Numbers" is activated;
    4) with soft proof activated make all the adjustments to the copy in order to get a picture as close as possible to the reference;
    5) resize, apply a touch of sharpening and save as jpg without the ICC;
    February 18, 2008
    >What you think?
    You have the first 2 steps Backwards. never mess with the original
    Finally I think the best way to go in order to produce nice images for the web is to soft proof. The idea is exactly the same you adopt before printing except in this case the device to simulate is a non-color managed environment.
    Put simply here my workflow:
    1) convert the original picture to sRGB;
    2) duplicate the original picture;
    3) setup a soft proof picking up your monitor profile as Device to Simulate and make sure the "Preserve RGB Numbers" is activated;
    4) with soft proof activated make all the adjustments to the copy in order to get a picture as close as possible to the original one;
    This should ensure your picture will looks quite the same assuming most of your viewer have a properly calibrated monitor.
    What you think?
    The Dell probably just has a somewhat better blue filter dsicovered in a rock in the Australian outback by Steve Irwin before a crocodile ate him.
    Just do what you're supposed to do in CS3 already and shut the --------up.
    Using your monitor profile as the color space guarantees images you see on your monitor will be perfect. The problem is that everyone elses monitors are either sRGB or calibrated to simulate sRGB. Previewing in Save for Web (SFW) attempts to show what images will look like on sRGB monitors when PS is set-up correctly (showing what the majority of viewers will see).
    I too had a 2407-HC and the problem is that even with correct calibration/profiling (I use a Huey Pro) it does not display the sRGB space the same way as a standard sRGB space monitor. Photoshop, for some reason, assumes all monitors are sRGB, it by-passes your calibration profile, and sends the image directly to your monitor (again, assuming the masses are operating this way)
    Calibrate your monitor, follow the guidelines for set-up at gballard.net, and forget about the weird SFW preview image (yes, even in the 2-up window that has "original" and "Optimized") or get a different monitor.
    I personally couldn't handle the difference between my 2407-HC and an sRGB monitor and couldn't ignore the color behaviour of photoshop. I switched to an Apple Cinema Display. I have discovered that the ACD is MUCH closer to sRGB space but is not exactly on either. No one's monitor is exactly on sRGB, but much closer works much better for me... I am much happier now.
    Personally, I think Photoshop should simply add a button that allows you to preview SFW through your own calibration profile... Something simple like "Calibrated Monitor")
    Many thanks to all the MUCH knowledgable people in here!!!!!
    Hi Buko,
    Thanks for your reply. But this solution works for me regardless of whichever working space that I use. I actually use Adobe RGB (1998). The issue I was attempting to address was that of color shift when Saving as Web, clearly demonstrated in the 2-UP view. By deactivating the Save as SRGB, the color shift is eliminated.
    My monitor is calibrated using a Pantone Huey and therefore surely for web-based work, which is obviously screen based, provided that my screen is showing the colors as accurately as possible to me, then when I save the images there shouldn't be an issue(?). As you quite rightly say, I cannot be responsible for those who view my images on an uncalibrated monitor.
    Please correct me if I'm wrong but should I really be concerned about embedding profiles in my web graphics if I'm confident that my colors are relatively accurate on my calibrated screen?
    Many thanks,
    Jareus
    February 17, 2008
    Jareus, the problem with using your monitor profile as your working space is that you are the only person on the planet with that profile. And because it looks good on your monitor guarantees it will look like crap on everyone else's monitor.
    If you use a working space that is a known quantity (sRGB, AdobeRGB, ect... ) at least your images will look good on monitors that are calibrated correctly. There is nothing you can do about the uncalibrated monitors.
    That last post on re-reading comes across a touch arrogant, what I meant to say is that maybe I misunderstood where this post had gone. I had an issue whereby PS CS3 would provide overly saturated images when using Save for Web on my calibrated 2407WFP-HC. I tried all the usual color management and profile tweaks that I could find on the web and then finally found Tancredi's post regarding the 'hidden' default(!) setting that converts all Save for Web output to SRGB, and suddenly (once switched off) in the 2-Up view my output was as per my PSD image! Eureka.
    My apologies, if this contradicts what you had discussed previously.
    Sorry Guys ... I simply posted it because it's the only solution that I've found that actually works! ... and it works regardless of the color management settings on my machine. Sure you're all not trying to over complicate the issue?
    Many thanks Tancredi!
    Wow... even I knew this was gonna be the wrong advice as soon as I read "...very simple hidden setting". All I can say is that this thread has become way, way too long for any new people to figure out all the info in here.
