  • October 31, 2007
  • 680 replies
  • 62290 views
Pete
    February 16, 2008
    Tancredi is giving appallingly bad advice and it should be totally ignored.
    (Actually, it wouldn't be a bad idea for a Host to remove the Posting completely.)
    In the first image in his Link, he shows "Monitor Color" as his working RGB space and he has also "turned-off" all "Color Management Policies".
    The very fact that he is having these issues means that his Monitor calibration is far-removed from sRGB and, despite what he claims, it is totally UNlike any other monitor on the planet.
    I'm beginning to think this is hopeless. People like Tancredi are obviously taking a shot in the dark and recommending something that, on the surface, works, but have no idea why, or why it's a bad idea for general purposes. He prefers to literally bury his head in the sands of ignorance and asks you all to blindly follow. This thread has been through this very issues and back several times already. There is no problem other than people not understanding what's actually happening between color managed programs, one's that aren't, and differing monitor gamuts. Oh well...
    I had the same annoying issue with my Dell 2407WFP-HC, and finally solved the issue with this very simple hidden setting in the Save For Web dialog box:
    [url removed by host]
    I hope this is of help to some of you.
    February 13, 2008
    > I have this option only in View -> Proof setup -> Custom ... Do I miss something?
    You are right. That is where it is. Sorry, my mistake on the location.
    The thing that you do need to be sure to do is to always use the Adobe Color Engine (ACE) and never the Apple CMM version.
    > When you Convert, leave "Preserve RGB Numbers" UNchecked;
    Ann I don't have anywhere the option "Preserve RGB Numbers" neither in the Edit -> Convert To Prifile and in the SFW windows. I have this option only in View -> Proof setup -> Custom ... Do I miss something?
    February 13, 2008
    >This is probably due to your monitor. Are u using a wide-gamut monitor or a narrower one?
    Michele:
    I am fortunate enough to still have a laCie electron22 blue III.
    >It occurs to me that the Tiff that he posted was never properly Converted into ProPhoto RGB in the first place and that it is really a mis-labelled sRGB.>
    >How did u check this and how can I verify it?
    It IS tagged as a ProPhoto RGB; and you can check this by drag-&-dropping your file onto a ColorSync Script.
    Library/Scripts/ColorSync/Extract Profile.
    However, in your case, your file was obviously incorrectly tagged with the ProPhoto RGB tag unless you meant the image to have an all-over scarlet color cast.
    If you use Edit/Assign Profile (with the Preview box checked), you can try out the effect of using different Profiles on a "Mystery-meat" file.
    With your file, the best-looking result seemed to be if I used sRGB.
    I then Assigned sRGB to your file.
    Now that it is tagged correctly, it can be Converted into any other space correctly and will also output via SFW correctly.
    and choose "Relative Colorimetric"
    with "Black Point Compensationt" checked.
    Your problem seems to lie NOT with your monitor calibration but in incorrect use of Profiles.
    > I do NOT see a color-shift on my Monitor in either Safari (which IS color managed to some extent) or in Photoshop when I use CS3's SFW going directly from Adobe RGB but leaving SFW to shift the space automatically to sRGB.
    This is probably due to your monitor. Are u using a wide-gamut monitor or a narrower one? I belive the last apply in your case.
    > Did you perhaps just Assign the wrong Profile to it at some time?
    That tiff comes from Vuescan and the output was set to ProPhoto RGB.
    > If I treat it as already being an sRGB (by Assigning an sRGB Profile to it) and THEN Save for Web, I get an exact match to the more neutral colors seen in Michele's Gallery Image #2.
    Will check this. Thank 4 your help.
    February 13, 2008
    That is not how it works for me.
    What other people see who use a non-color managed browser (like Firefox) on heaven knows what sort of a monitor is obviously beyond my control.
    If working in a very wide space like ProPhoto is not producing the results that you want for the web, the obvious answer would seem to be to work in a "narrower" RGB space while preparing images for the Web.
    Concerning, Michele's photograph:
    Did you perhaps just Assign the wrong Profile to it at some time? Or use the "Keep RGB numbers" option?
    Very nicely put... makes sense to me, but then so did marrying my first wife!
    February 12, 2008
    Here's an attempted summary of the main points discussed in this lengthy topic...
    "Simply" put: Seeing a colour shift in SFW does not necessarily mean anything is wrong at all. In fact, if your monitor can display a significantly wider gamut than sRGB, and is properly calibrated and profiled, you SHOULD see a noticeable shift in SFW. The difference is that in the normal Photoshop image view, Photoshop is using the monitor profile to display an accurate colour managed image...whereas the SFW preview window is NOT using the monitor profile, it's just throwing it up to the monitor (so to speak) to display however it ends up displaying. Uncorrected.
    This is as it should be, since most web browsers are not colour managed...therefore SFW is previewing what it will look like in most web browsers ON YOUR MONITOR.
    The best thing to do, assuming one's monitor is properly calibrated and colour management settings are correct, etc, is to trust what your file looks like in Photoshop and ignore any "incorrect" appearance in SFW or in a web browser.
