  • October 31, 2007
  • 680 replies
  • 62290 views
Pete
    > So the problem seems to be your monitor: either it, or your calibration, must be faulty.
    Now this might be the case. Actually I am calibrating an EIZO CG241W with a Spyder2 and the Colornavigator software and I suspect that the Spyder2 doesn't handle wide-gamut monitor calibration well. This is driving me crazy...
    February 12, 2008
    Michael: I have looked at them and this is what I get:
    Your original Tiff when viewed in Safari directly from your Site matches your Gallery #2.
    When that Tiff is downloaded to my Desktop and opened and viewed in Photoshop CS3 it will match the Safari rendering and Gallery #2 ONLY if I soft-proof it in the sRGB space.
    If I change my RGB working-space to ProPhoto, your Tiff then matches your Gallery #3 (very red) image.
    If I then make JPEGS, whether by using SFW with sRGB checked; or by converting the file to sRGB before saving; or by converting to my monitor-space and saving for web; I get identical results in all cases.
    All three now match your Gallery #3 image AND they match your original Tiff when viewed in the ProPhoto space.
    >It only APPEARS to work because, unfortunately, your monitor is not properly calibrated.
    It still might be a monitor profiling problem but really don't know because already tryed to re-calibrate my monitor few times and still getting the same output.
    BTW I have done few more test. I have produced several "Save for Web" samples and uploaded them at this URL: http://photo.net/photodb/folder?folder_id=808399. Once in the page click "Details" to see the workflow used to produce each sample. You can also try yourself with the original image used to start with. It's a 5.8Mb tiff file and you can found at http://www.micheleberti.it/docs/Box%20038%2015.tif
    If anybody out there has a flawless color management workflow and is using a wide-gamut monitor I would appreciate if he/she would give it a try with the original image and the SFW. I wonder if anybody can get an image equal to the second picture posted in the folder linked above.
    > It has nothing to do with you calibration. It has everything to do with your monitor's gamut.
    I understand why when looking an untagged image with a wider gamut monitor colors might be off but I wonder how a wider monitor can modify the way a picture is saved with the Save for web command because I see color shift also in a normal (no wide gamut) srgb monitor
    It has nothing to do with you calibration. It has everything to do with your monitor's gamut. This has been discussed literally over and over in this single thread alone. All you have to do is use a browser that recognizes embedded profiles and tag your images. This is going to be the way of the future as more as more monitors move into large gamut capacities.
    I was using a Dell 2407wfp-HC wide gamut monitor and yes, I had the same problem. All I know at this point is that photoshop CS3 prefers sRGB gamut monitors. I switched to an Apple Cinema Display, which is much closer to sRGB color space and now everything works fine. If you must work with wide gamut, I don't really know what to suggest as an alternative to photoshop. Maybe someone else will have a recommendation.
    Edit: and it seems it is not possible to properly calibrate a wide gamut monitor for use with photoshop. However my sRGB Cinema Display, with smaller color gamut, calibrates just fine.
    February 11, 2008
    >I really don't know why this works but it amazed me when I discovered this. >
    I suggest that you start by following the instructions on this site:
    http://www.gballard.net/nca.html#getagoodscreen
    Peter,
    don't know if you have solved the issue or not but I can only say I am experiencing exactly the same problem here.
    I have a fully calibrated color management workflow and the only way to get an image without color shifts in the web is to first convert the picture to the color profile of my monitor (from ProPhoto RGB to my custom Monitor Profile) and then run the save for web. This is the only way I get what I see and colors on the web are consistent.
    Please try yourself and let me know.
    I also wonder if someone out there could explain this behavior. If could help explaining I am using a wide gamut monitor which cover almost the Adobe RGB 98 color space.
    Ramón G Castañeda
    >but remember including profiles increase file size...
    by a miserly 4kb or so. ;)
    >> Your advice as to tagging images with the ICC profile
    I tag very very very few images on the web...for any number of reasons previously stated
    >> The rollover images you showed on your site show a difference between the tagged sRGB (or Adobe RGB and Apple RGB) and the untagged images in Safari, but the (paired) images don't register as different in Windows XP in Explorer.
    That's precise and the whole point of the tutorial.
    Tagged sRGB would be the only logical way to go on the web at this time if you want to tag images with ICC profiles, but remember including profiles increase file size...
    When the world Honors embedded PAGE profiles, I will celebrate.
