질문
Recovering accidently deleted parts
  • March 28, 2024
  • 3 답변들
  • 1332 조회
How can I recover deleted parts from an object?
I used the history brush tool but it continuing on erasing with white color. it didn't restore what was erased.
I attached my video for this.
이 주제는 답변이 닫혔습니다.
3 답변
mglush
Have ou closed your file after deleting the parts you want to get back? If so, then that area is gone and you will have to reconstruct it. If you haven't closed the file, then in your History panel, you should be able to go back to the history state before you made the error and click on it to get it back. But, if you made more changes after you went back then you could have deleted the history by making more modifications to the image.
imagenry_b작성자
As known "History Brush Tool" can do that as in this video (see 1:02):
https://www.youtube.com/watch?v=2TA5FvZgXsU
I done this via "History Brush Tool" also but I'm not sure if I went far steps ahead it can restore it.
D Fosse
You need to mark the history state you want to revert to.
Kevin Stohlmeyer
Check your History panel and what step has the brush icon clicked - I'm betting its going back to the start where you had a blank white background.
imagenry_b작성자
Ok when using the history it will revert all my work back to that point. but what I need is restoring the erased part using the eraser or paint tool without using the history.
like in this video (go to 3:29 ) he just erased the text then restored it again. I want to do the same but for the image.
https://youtu.be/tASO3UHJb7w
