PSE 2022 after months of loading correctly, will not load.
  • March 17, 2022
  • 479 views
What happened? I can't load PSE 2022 anymore from either Organizer or the PSE executable. I've restarted, opened Task Manager to see what is loading, etc. PSE is listed briefly, then dies.
Correct answer BLanellA
Spent a couple of hours on chat with Adobe on this. The rep renamed the %appdata% folder, updated VB, uninstalled PSE, reinstalled. He basically applied Windows 10 updates. So it's fixed now. Loads fine.
BLanellAAuthorCorrect answer
BLanellAAuthor
I also loaded Organizer and attempted to load a file in PSE. Same result. The "loading PSE workspace" appeared, then died.
MichelBParis
quote
By @BLanellA
What are your OS and PSE versions?
I had a similar experience twice yesterday with the February update of PSE2022 on Win 10.
After waiting a few minutes and rebooting the computer, all was well again. I tried launching PSE from the editor shortcut and saw no difference. I have never seen PSE disappearing like this without any error message in the past.
BLanellAAuthor
Thanks Michael--
Will someone from Adobe chime in on this problem? Maybe? I use my computer for work at home, creating marketing brochures in PSE. So I'm stuck.
Thanks again
