100% CPU load, no GPU load
  • September 9, 2020
  • 4 replies
  • 2204 views
hi,
i just installed Premiere Pro on my computer (self built), and i have updated and performed a clean install of the latest NVidia drivers for my graphics card, but for some reason my graphics card won't help render live view. the CPU goes to 100% even when dropped to 1/8, and i can't watch actually see what my transition effects or general effects are doing or even adjusting them. please help.
running latest version of premiere pro, and yes i have enabled gpu acceleration in project settings.
specs:
I7-7700k 4.2Ghz
GTX1080
16GB RAM
500GB PCIE SSD
windows 10
OMG, I finally got it to work!. I uninstalled Creative Cloud, Premiere Pro and Media Encoder all AGAIN for the umpteenth time AND the drivers again. Then I ran the CC cleaner tool. Reinstalled the 451.77 driver, then the CC and Premiere, and then just for the hell of it I installed the 451.77 driver again on top of itself -- fired it up and it finally plays , including the 57GB 4k 10-bit 4:2:2 file that spurred me to install Premiere since it won't run on DaVinci Resolve. I've been installing and uninstalling the same things over and over again for three days, including other Nvidia drivers as well. But finally, the drivers that installed on my second try finally worked on the about the 12th installation.
I think, at this point I'm going to buy Resolve Studio for $300 and only use Adobe when absolutely necessary -- and for Lightroom, but if anyone can suggest something they like more than Lightroom for organizing and color correcting images, please let me know.
I've got the same problem dude, this must be something to do with an update with NVidia drivers or Premiere Pro - or both.It's honestly so ridiculous tho cos Premiere has been working fine on my computer up until like 2 days ago. The program is literally unusable for me rn ugh.
Same here, except I wasn't running Premiere until I moved it to my new machine yesterday. Everything has been running great in Resolve for 2 months -- and still is. I never could have imagined these issues wih my brand new ASUS Zephyrus G14 with specs that smoke nearly every Intel-based laptop. I hope they fix it soon... I'll be sticking with Resolve no matter what though now.
You did not specify which Nvidia GPU you actually have. Newer versions of Premiere Pro now no longer support any GPUs that are more than two or three generations old. That will tell us which driver version is compatible, and whether or not Nvidia had depreciated CUDA support for a given GPU in the required driver version.
WeAreMoose
Yes he did,
GTX1080
no, the effect i'm trying to use has the icon for accelerated effects...
One more possibility:
The problems may be caused by the improper uninstallation of the old drivers during the update process. Many users simply installed the newer drivers on top of the older troublesome drivers (which is the default procedure). That always leaves a mixture of both old and new driver components, which almost always results in a total mess. To minimize that risk, you must completely uninstall all traces of the older driver before you can install the newer driver. This can be done during the Nvidia setup program for the newer driver using Custom settings, and clicking the checkbox labeled "Perform a clean installation" to put a check mark inside that box.
WeAreMoose
Are you on Software Only perhaps?
Ivar5C8DAuthor
What do you mean by this? I specified that I was using the Cuda accelerated option?
WeAreMoose
OK must've skipped that bit, some effects in your timeline are GPU accelerated, and some aren't. You can tell the difference by clicking the little icon which looks like a play button in your 'effects' window. Apply a GPU heavy effect on a clip and see if your GPU helps you.
