mattheww39232501
100% CPU usage, and it's NOT the hardware
  • February 26, 2020
  • 7 replies
  • 31365 views
I've read, and searched, and watched, and updated, and _fill-in-the-blank_, all to no avail.
Editing videos has now become virtually impossible - if you can't watch them in edit you can't fix them.
Every time I work in a file - doesn't matter resolution, fps, display output (set to 1/4, btw), CUDA set for rendering, etc etc etc - it blanks the cpu at 100% and crawls.
If anyone has a fix action I can try, I'm all ears. Otherwise, I'm gonna have to find something else to edit in. Which stinks, because I like Premiere.
I had this same issue the other day as well.  After tearing my hair out for a few hours, I did eventually find a solution.  The issue isn't your hardware, it's the source file you're editing.  If it's a file Premiere accepts but doesn't like, it will 100% the CPU and make you go mad.  The solution is to transcode your source file to a more acceptable format first.
One explanation I read was that this is due to VFR (variable frame rate), which Premiere hates, and transcoding to SFR (single frame rate) fixes the problem. I haven't tested if that's true, but I do know that exporting the source file to MP4 and then editing that file stopped the issue completely.
I've also had this issue since purchasing my new MacBookPro in July 2020 - it's a:
MacBook Pro (16-inch, 2019)
2.3 GHz 8-Core Intel Core i9
32 GB 2667 MHz DDR4
AMD Radeon Pro 5500M 8 GB
Premiere Pro is a no go these days. Seems to throttle around 1440% and then it crawls.
Could Adobe fix this?
Depressing after spending £3300 on a new computer for editing and discovering that it can barely do this.
tell us what your source properties and sequence settings are...  Have you tried working with the intel version?
Hey mrgrenadier,
Mostly 4K with a few HD shots in there. Have tried using procies and without. Sequence settings below.
I just bought a new HDMI 8K cable for my exetrrnal ACER monitor, from Amazon as read this could be an issue with laggy machines. Haven't got into a full edti to test the new cable but will be doing that tomorrow. All 4K footage with Proxies.
n8xxx
So what's up then? I don't understand how this is happening to so many and its basically crickets.  I can't use Premiere now and I am about to bail. I might have to use DaVinci even though it is not ideal in the least and I work slower but at least I have full control of my workflow and not stuttering in playback and basically unable to work at all.
Adobe Employee
April 16, 2021
n9xxx,
Sorry about that. What are the exact specs of your computer? What kind of media are you editing with? Which camera are you using? All these things really matter.
Even just dragging the blue line on the timeline stutters, it's maddening.
@n8xxx Try these for starter
1) go Preferences > Audio Hardware > Default Input => select "No Input"
2) Turn off Nvidia G-Sync in driver control panel
3) Try if most basic display setup, i.e. FHD@60Hz has same issue
Did you ever figure out what your issue was? I'm currently experiencing this and it's extremely frustrating.
My build:
Ryzen 9 3950x (16 cores) 3.85ghz
RTX 3090 Founders Edition
64gb of DDR4 4000hz RAM
MSI X570 Carbon Pro Motherboard
1200w PSU
My boot drive is a 500gb m.2 SSD
My working drive is a 2TB m.2 SSD
My external drives are just used for storage once I finish a project so they shouldn't impact anything.
Running Nvidia Studio Drivers v462.31
Premiere Pro 2021 v15.0.0 (Build 41)
Windows 10 Pro Version 1909
I had a PC that was much weaker than this and had no issues. Now I spent almost $5k on a build that can't run premiere without ramping my CPU up to 100% and forcing me to quit the program.
I'm shooting with an a7s iii so I know that the files can be a little rough to edit but I haven't had any issues until recently and now I simply can't use premiere.
If anyone has any suggestions I'm all ears! I have already tried turning GPU Acceleration on and off and it doesn't seem to matter. This is also happening to me every single time I try to use the program. Doesn't matter if I start with a brand new project and import the footage directly from the working drive, it ramps the CPU up to 100% and then I'm unable to use my computer until it quits the program.
Kevin-Monahan
Hey Ben,
Sorry about this. I suggest you test in 15.2 Beta. There are some under the hood changes which may assist your particular hardware. Let me know if you have better results.
Thank You,
Kevin! You're a legend!!
Don't want to jinx myself but so far so good! Everything is loading much quicker now. Even while loading up the previews for each video, I was able to import 543 video clips from the a7s iii and my CPU usage sits around 50% while it's fetching previews and then drops to around 7% once it's done with that.
Thank you so much for your suggestion!
Your point about the newer AMD cards offering H.264/265 decoding assistance is a good one. And Premiere doesn't use that, which sucks. It would sure work a lot better if it did. The last bit of decision on my 'new' machine before I send 'em money is which v-card. And it's between an Nvidia and an AMD. I want them both used fully.
The reason for the suggestions to go to the UserVoice system is two-fold.
First, every post over there and every comment added to a 'current' post is read by an engineer. That is the system they use for users to communicate to the engineering staff ... this forum is for primarily user-to-user help, which for many things is a fast way to get something working again.
Second ... every post and comment there is collated and delivered to the upper managers ... those above "team" level ... who are the ones that determine budgets and such. Those folks live by metrics. Posting something on the UserVoice system gives them metrics. And I do mean, at Adobe ... metrics are almost everything for upper-manager decisions. Frustrating but true.
And at MAX, what we ACP's heard from the engineering team was that they need more metrics ... more detailed posts ... of user difficulties. Again, two reasons.
First ... they only have X number of machines in-house, and Y number of beta-testers. Premiere runs on the widest array of gear/media of any major NLE, and they simply don't have enough machines to nearly duplicate every combo of gear bits, other installed apps/utilities, media, and such that can be a part of a problem. What they can't replicate, they can't see, they can't fix.
And second, it shows the upper managers that though the general user base numbers for performance are good, they still have a ton of serious things affecting smaller groups that need attention. Which means ... budgeted engineer time.
Is it a right royal pain to go file things on U-V? Yep.
Is it necessary?  Yep.
Does it have an affect on things? Yep.
This app is used daily by many thousands of users. When it ain't working right, it's best to squeak where squeaking can do something.
Fair enough Neil, I appreciate your reply and your constructive approach. I will try to gather all the details I have discovered so far and write a post. I think everyone just want this performance issue fixed asap, as it affects job performance and caffeine levels to much 🙂
tobiq may also be having the same problems, but ... not nearly everyone else. Premiere is used by thousands of people, including a lot of broadcast shops and posthouses daily. So a lot of folks are doing fine.
Which is not your case. Something very odd is going on to cause the app to go full-on with the CPU yet crawl.
To start even guessing, it's always useful to have the full data ... system, OS, version of Premiere, where Premiere is 'housed' on your system, storage and connections of storage to computer, media used, effects, any third-party software touch the media, all that. Troubleshooting involves a bit of tedious data study and wrangling especially at the start.
Also realise that there is extreme ignorance to issues related to Premiere on these forums, they'll blame your software/hardware to the end of days..
Just say you have a problem is not getting you anywhere.
Hardware and workflow are a big part of getting things to work correct.
Hi there, me and everyone else has the same issue i'm afraid..
