[22.6.2] Rendering of audio is not done, when changing speed.
When you import an audio file into the time line and it is changed via the clip speed/duration window, and you render, the rendering window appears but no progress bar and no process happens.
I have run version regression tests, and up to version 22.5 everything works smoothly and no problem is detected the rendering starts immediately.
Since version 22.6/22.6.1/22.6.2 I have detected this problem.
I ask if it is possible to solve it.
Thank you.
