30 FPS in a 24 FPS timeline
  • April 11, 2023
  • 9303 views
I am creating a film that I shot in the begining at 30fps and have added 24fps footage. I hope to get the best quality with my footage. Im noticing the shots at 30fps look choppy as premiere automically removes additional frames to fit 24fps timeline. Can I fix this without manipulating the footage? Does premiere allow changes in frame rate for sections of a project to match the ideal frame rate of the shots?
Thank you to all for the consideration!
MyerPj
You can have many sequences (timeline). You can have 24 and 30fps sequences. But, I think it would be best to try different options like MG said. Try both, and take it all the way out to export to make sure you are moving on the best path.
Thank you! I have diffrent sequences with diffrent frame rates I still need to export in either 24 or 30 so setting at one or the other is best option based on what you are telling me. Thank you again for your help!
select a clip in the timeline and right click and choose "time interpolation."  You'll see there are 3 options, frame sampling, frame blending and optical flow.  frame sampling simply drops frames, frame blending will mix frames and optical flow will actually create new frames which can be pretty amazing or pretty terrible depending on the amount of movement and detail.  I'd suggest you try both editing into a 24p and 30 fps timeline and play with these options to see what gives you the best results..  Render the clips in the timeline to be able to judge the relative merits of each option.  ...  Is all your material progressive?  that can also be another complicating factor.
Incredible! I will givde these recomindations a try. I was able to get the play back smooth using a 30 fps timeline. What do you mean by progressive?
interlaced and progressive video are 2 different formats and I honestly don't have the energy or time to explain the differences.     Found this with a quick google
https://www.sony.com/electronics/support/articles/00032537
but probably won't make it clear to you.    It's complicated and the only reason I know all about it is that I've been working in video for a very long time...  and for the most part it's not that important unless you have to deal with material that is shot interlaced or working with older material... or are delivering where you're required to follow certain specifications...   Maybe  someone else will be able to go into greater detail...  or I may be able to put it down in writing after I've had some coffee.
