720P 120FPS Sequence Preset
  • December 16, 2012
  • 8 replies
  • 43392 views
Hey
I'm running Premiere Pro CS6 v6, Installed latest updates, Windows 7 64bit, My source footage is H.264 in a .MP4 format. I'm using a Go Pro Hero 3 Black edition at 720P, 120FPS.
Is it possible to create a sequence preset for the Go Pro Hero 3 at 720P 120FPS and/or for all the other Resolutions and FPS?
Kind Regards
Toby
You can do all this inside Premier
Not sure why people will always assume they know best instead of just answering the question. Of course if you film at 120 or 240 you will want a sequence to be in 120 or 240 so when you you reduce the speed of the clip to 10% that 240 fps is now 24fps and really smooth. if you put a 240pfs clip in a 30fps sequence it drops all your extra frames and if you slow it down to 10% you will only have around 3fps which looks like crap
People should not ask why you want to do something a certain way and just answer the question
Its easy
right click on the clip in the in the project window and select create sequence from clip, then you will have a 240fps or what ever frame rate it was filmed at.  Then once you stretch the clip where ever you want it to be slow mo, you can copy to a master sequence if you have one at a lower framerate where your putting a lot of footage together that is at different speeds, or just export it at the 30fps with out losing any of the frames where you stretched it so you will have 24fps slow motion if you reduce its speed to 10%
Steven L. Gotz
johmorjias,
You are missing a few important facts.
If you put a 240fps clip into a 24fps sequence, it will only show every tenth frame. And be VERY choppy. What you need to do is "interpret" the footage to 24fps, then it will play 1/10th as fast, and use all of the frames. By the way, I don't think that Premiere Pro can create a 240fps sequence yet. Perhaps, but I don't think so. Feel free to prove me wrong.
The reason that experienced users ask what the original poster really wants to do is because often they ask the question in an odd way because they just don't have the right words to use. So we ask, and then we help.
Perhaps you should check out the information you provide before you type up a post in a forum in an attempt to answer questions.
artofzootography.com
@johnorias, I'm interested in your findings. Did you see any difference in the smoothness of the slow motion after trying interpreting footage? In reading this, your method seems to make more sense, but I've always used interpret. Would love to be able to do this by just dropping into a timeline as you and the Adobe rep suggested. Thanks.
In the few I have done since, I tried both methods and I honestly could not see any improvement using interpret. I could be wrong perhaps my eyes are not good enough but the outcome looked the same to me. So I continue to do it the way I have been doing it. By just creating the sequence from the clip and letting it create a 120fps sequence. I would strongly suggest giving it a try.  Unless I am doing something wrong when trying to use interpret they look the same to me, and my outcome looks really smooth just by creating the sequence using the clip and slowing down the parts I want slowed down.
I believe what you are wanting is a program like imovie for apple. this video is a very good example of what it does and it does it for 120 fps http://youtu.be/A-Xbtbs0yZc . I've been trying to find the same thing for PC also, but to no avail. everything I find wants the video converted to 30 fps or less first, but I want to be able to edit the 120 fps file before conversion like in the clip above.
Um, that video is not playing 120fps in real time, it is "conformed" to a slow-motion rate.
You can accomplish the same task in PrPro by right clicking on the clip in Project, Modify, Interpret Footage and change the frame rate to "Assume this..." and set it to your sequence frame rate.
If you want to view 120fps at real-time and not skip any frames, you will need a software player, video card and display all capable of 120Hz refresh rates.
Good luck with that, and let us know if it was worth it.
display capable of 120Hz refresh rates.
There's the rub.  I've never seen a computer monitor that goes over 60Hz.  And even when a TV can go to 120Hz, it's a special mode that's doubling the normal 60Hz signal, it's not something that the TV is taking in at 120Hz.
The point of 120 fps is slow motion.  It'd be very difficult to see the full 120 frame rate, so what's the point of worrying about it?  You shoot 120 to slow it down,  If you don't want to slow it down, don't shoot 120.
Easy, done.
jdstoo
The solution, as the OP was trying to ask, is for Adobe to create or allow the creation of higher framerate sequences. If you can create a 120fps sequence, you will not drop any frames and your footage will play back as it was shot. You can then use any of the tools available in PP or AE to do as you please with it.
Steven L. Gotz
That makes sense, I suppose. But what players can play back video at that frame rate? I imagine there must be some, but how many and how commonly are they deployed? As stated above, usually 120 fps or 60 fps is usually shot that way to take advantage of the improved slow motion when played at "normal" frame rates.
I am not saying that Adobe should not make it possible for one camera, or even a few cameras, to be able to record twice or four times the frame rate of the rest of them, and still play it back at the native frame rate.
I am saying that Adobe has finite resources and the actual need to edit it that way is limited by the fact that nobody could actually play it back that way. You could always put in a feature request. Eventually, if enough people do so, the engineering resources could possibly be applied to the problem.
But again, if film is 24 frames per second, most video recorders use 24, 25 or 30 frames per second and even my camera can record 59.94 frames per second, the human eye isn't really going to be able to take advantage of something with a frame rate twice as high is it?
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
jdstoo
I know this is an old thread but if you want to see what's really happening when you drag high framerate footage into a lower framerate sequence, take a look at this video, http://www.youtube.com/watch?v=W_ry1YAwcIM. Personally, I think frame dropping isn't an acceptable answer to your question so I'm glad you came here to ask about it. Maybe someday Adobe will see the value in being able to render higher framerate footage at its native speed without dropping frames.
Steven L. Gotz
How would that be possible? If I shoot 60 fps and put it on a 30 fps timeline, what should the program do? It sees 60 frames and tried to stuff them into one second. All it can do is drop frames. It can't display to frames in the time that one frame is normally shown. The players would not know how to deal with a variable frame rate video.
Yep it will, 59.94.
Not sure if it did the same with the 120fps of the hero 2. would assume it would.
My question is that if i drag in the 120 fps right interpet the footage to 30fps, am i doing this on the 120fps or is premiere dropping 60 frames and doing it to the 59.94 fps?
cheers
SteveHoeg
Adobe Employee
Adobe Employee
December 28, 2012
Premiere Pro's renderer is framerate agnostic, don't let the lack of sequence presets stop you. Dragging a 120fps clip to the new sequence icon and internally it will be treated as 120fps.
shooternz
I am not convinced that the OP actually understands framerates and so maybe he is under the misbelief that he needs to match his camera framerate to a sequence framerate.
It seems more likely that a 1st time poster with a new camera..is more likely to be wanting Slo Motion.
A good link to how slo motion and framerates interact might be helpful to him. (Wish I had one for him)
Then again...he might really , really want his footage in a 120 fps sequence. ( But that would be a first around these parts)
Steven L. Gotz
I suggest you ask the folks at Cineform support for recommendations on editing that footage. They may have a way to deal with it in Premiere Pro. My guess is that you shot at 120 in order to slow it down. Perhaps at some point in the conversion process to the Cineform codec, the Cineform software deals with it. I don't know. I don't have a GoPro camera.
If anyone knows, Jake at Cineform will know.
At the moment there's no realistic broadcast distribution mechanism for 120p footage, so the only reason for recording in 120p is to play it back in slow-motion or to extract still frames. You can play 120p clips at 'full speed' on a computer (e.g. with Quicktime) but you won't actually paint all 120 frames a second to your screen unless you're on a beast of a machine.
The Hero3 writes its 120p footage at 119.880fps so when you drop it into Premiere Pro it will create a sequence with the highest NTSC frame rate it can handle, of 59.94fps*. That automatically gives you a 2:1 slow motion effect, if you want to play at normal speed you have to sacrifice half your frames (by setting the clip speed to 200%). The only problem with all this halving and doubling is that your audio track will be chewed - it's pretty unimaginable that anyone would want to keep the audio channel from a 120p clip, but if you do, it's best to pull it out as a separate file. Audition CS6 can import 120p video references and plays them at full speed so it's easy enough to slice apart.
*Interestingly, After Effects also has an import limit of 60fps but will reinterpet to 99fps if you ask nicely. It won't go to 120.
For those who care, here's a specs dump for a Hero3 720/120p file:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode  : Constant
Frame rate : 119.880 fps
Original frame rate : 29.970 fps
Color space  : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.281
Title : Ambarella AVC
Audio
Format : AAC
Format/Info  : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Title : Ambarella AAC
August 14, 2013
>>"I've never seen a computer monitor that goes over 60Hz."
120Hz monitors are popular among high-end video game players.  There are more than a dozen models avaialble:
http://www.blurbusters.com/faq/120hz-monitors/
>>"At the moment there's no realistic broadcast distribution mechanism for 120p footage"
Good news!  The web is now a potential 120fps video distribution medium; and some computer users use 120Hz computer monitors now.  There is now a way to speed up 120fps slow-motion to 120fps real-time, and it was recently discovered that all the popular web browsers (Internet Explorer, Chrome, and the new FireFox 25+) using the <VIDEO> element are now capable of playing back at 120fps in real time on a 120Hz computer monitor:
http://www.blurbusters.com/faq/real-time-120fps-video
In general, any machine capable of playing back 1080p@60fps, is easily capable of playing back 720p@120fps.  Both are pretty similiar bitrates.
Premiere can handle resolutions up to 10,240×8,192, for framerate the maximum is 60 fps.
Drop your footage in a 1280x720 60 fps sequence and I think it will be ok.
