A problem with multi-camera editing (24.2.1 Build 2)
I have been using the Multi-Camera view for many years and there is some kind of change that is causing this very irritating problem with this recent version of Pr . The problem occurs when I make a cut using the cutting tool and immediately select a new camera angle. I expect that the segment to the left of the cut will stay on the old camera angle and the segment to the right of the cut will acquire the new camera angle, but just the opposite happens. The camera angle on the left is changed to the new camera angle and the camera angle on the right remains the same, i.e., the old camera angle. But when I wait a few seconds after I make the cut before selecting the new camera angle then the problem goes away.
