A1 audio = only left ear. A2 audio = only right ear. A3 audio no sound..
This problem is only at the timeline.
A3 audio and below, no sound..
Seems like the problem came after the update.
Can someone figure this problem out?
Filip5E50Correct answer
Yeah, figured it out yesterday. Idk why they changed to this as standard for me ;/
So i just set all these to "0" and "standard"?
Thanks a lot for answers!
I think certain sequence presents (like Broadcast) default to A1 = left, A2 = right, etc.
You can put them back to normal as follows. In the Window menu, go to Audio Track Mixer. In the Audio Track Mixer panel, set the Balance for A1 and A2 to 0. (So the round knob with the line looks vertical.)
I would not suggest that specific preset, as it is by color space designed for 12 bit RGB media ... Full range ... not the proper limited range for 8/10 bit YUV (Y-CrCb) media that is that vast majority of Rec.709 media.
If you are not sure, you do not have 12 bit RGB designed for full range use.
problem: i've got it, we are selecting the seq. from the broadcast preset and from which we've selected mono discrete,
Solution: create the seq. from HD 1080p preset and you won't have that problem...
it'll solve that,
I hope it'll help.
Filip5E50AuthorCorrect answer
Christian.Z
also, scree grab of your aidio preferences
Sounds like it's got 'dual mono' ... A1 is left, A2 is right.
If you made a screen grab of your timeline panel showing the control header block to the left, the little icons in the track headers will tell us what you're set to.
