Adding speed, scale, and position effects on same clip
I've been trying to use the speed ramp tool on a clip and also position and scale it to be where I need it to be in the frame.
Every time I try to add scale and position keyframes in addition to the using speed ramping strange things start to happen. Is there a way to layer effects and use multiple keyframes for different attributes?
Also, sometimes when I have multiple keyframes, if I edit one later in the timeline it doesn't change anything where I placed it but it changes things earlier in the clip...not even at a keyframe. This makes no sense to me. Then, if I 'remove attributes' sometimes my entire clip just disappears.
I'm not sure if it's all related somehow or if they're seperate issues. Any help is appreciated!
Thanks!
R Neil HaugenCorrect answer
Apply either the scale/position changes and nest the clip, or the time ramp changes and nest the clip.
To nest a clip, right click on the clip, then select "nest".
December 18, 2020
I thought I had tried that and was getting the same results but I'll try it again and see what happens.
Thanks Neil.
