Adjustment Layer is not working!
  • July 29, 2018
  • 4 replies
  • 42713 views
I have a serious issue with the adjustment layer fea
whener i make a new adjustment layer and try to apply a preset or new setting on it, it’s not responding or reflecting at all as example I applied a transation preset on the adjustment layer but still the timeline goes on as it’s not even excite
anyone can help?
    Izaacmark,
    A screengrab of your timeline showing the header block and the Effects Control Panel for the track not working would be useful ...
    HI Togehter,
    i have a serious issue with the adjustment layer.
    I want to preperare a zoom transition in the adjustment layer. So I need my adjustment layer to be able to
    change the scale by setting keyframes. However no matter which clips I set below the adjustment layer
    the scale of my clip is not changing at all...
    I already created a bunch of new layers without any other effects active in the layer... nothing happens.
    Is there anything I need to take care of to make my adjustment layer to be able to change the scale of clips below?
    Please help...
    Hi, Lindav,
    I once had the same issue but it's nothing technical or complicated.
    To do things like this with adjustment layers, you must apply the 'Transform' effect to the adjustment layer, and operate with that.
    It feels weird doing this, but it'll become natural quickly. I hope that solves it!
    Anders,
    The Transform effect is in the Effects list. Just type "trans " in the search box at the top, under Video Effects the Transform effect will be visible. Drag/drop that to the AL. Make changes for scale, rotation, skew and other things on the Transform effect in the ECP.
    Hi Neil,
    I have already used the Transform effect in my respective adjustment layers, but they still don't seem to work. However, only the Adjustment layers in 1 specific track (V3 in my case) doesn't work - the rest of the adjustment layers do. I tried making a new track and pasting the Adjustment layers over, but it still does not seem to work.
    Hi, all.
    I believe I may have a solution to this. I was having the same problem as most in this thread page, where my adjustment layer wasn't actually adjusting the layers beneath. I was trying to make a simple scale up of the layers beneath it, but nothing was happening.
    As mentioned, you have to apply the 'Transform' effect on an adjustment layer to do what I am trying to do. With that in mind, it still wouldn't work. I eventually noticed that in the 'Motion' section of my effects panel for the adjustment layer, the scale was, by default, set to 0. Once I scaled my adjustment layer up to 100, i.e the size of my frame, the effects of the 'Transform' effect then took place, and worked.
    I hope this helps some of you, and apologies if it isn't the solution. It's quite a subtle one. All the best, everyone.
    Transitions are best applied directly to clips.  Effects are normally what you'd apply to an AL.
    It all depends on the workflow, sometimes we apply effects or presets to a clip, then we want to add other
    effects to create seamless transitions or so ... in such cases we apply some of the effects straight to the clip,
    then we apply the other ones to an adjustment layer, or we nest the clip and apply other ones ... The user does
    not give us enough details about the workflow to be able to give accurate answers. If they are using video effects
    presets created using the 'Motion' properties, these will not work on adjustment layers. In this case, the preset has
    to be recreated using the 'Transform' Video Effect and save the Transform preset properties. If as they state that
    nothing happens on the adjustment layer, then most likely that they are adjusting the Motion properties.
    I had the same problem. I'm a beginner using AE for one specific text effect so I don't know how/why this worked but I recreated an adjustment layer, first clicking on the initial layer that I wanted to adjust and then adding the adjustment layer and it worked.
    If the preset is applied to the 'Motion' properties, this will not take effect on the layers under an Adjustment Layer. For 'Position', 'Scale', 'Opacity' and 'Rotation' properties to work on adjustment layers, a 'Transform' Effect needs to be applied to the adjustment layer, and those properties should be adjusted in the Transform Effect properties not in the Motion properties. This will take effect on all the layers under the Adjustment Layer.
    You can also apply the preset you have directly on the clip, it will work. If your clip already has other effects or presets applied and that was why you are using an adjustment layer, you can also nest that clip and apply the preset to the nested sequence of your clip.
    You have many options, it all depends on how your workflow is structured
    There is only the following properties: motion, opacity, time remapping. Missing "Transform effect" properties.
