Adjustments not working in Blackmagic Raw plugin
  • May 18, 2022
  • 867 views
 I am trying to use the Blackmagic Raw plugin to adjust the settings of the original source file. All of the guide I have seen mentioned that I should see "Master" under the effects control tab but I only see "Source". It does give me the option to change the settings but in the program monitor I am not seeing anything change. Am I doing something wrong or is this a bug with the plugin?
I'm using Premiere Pro version 22.4.0 (Build 57)
I'm working on Macbook Pro 2021 M1 Max with 64GB ram running MacOS Monterey 12.2
Correct answer Bruce Bullis
Master was renamed to Source.
Bruce Bullis
Bruce BullisCorrect answer
DJASH_EAuthor
Thank you for your response. That does clear up the confusion with the naming but it doesn't solve the issue that when I move any of the sliders under the master/source tab it does not make any changes to the file in the program monitor window. If I make changes via Lumetri then I see the changes but if I make changes via the Braw Source window nothing happens.
Bruce Bullis
The behavior you've described, suggests that there is no BRAW clip visible in the Program monitor, at the current time.
In the scenario above, you mention Lumetri; is a Lumetri effect applied as a source clip effect, to the same clip, as well?
