Nov 7, 2017 10:34 PM UTC
Adobe Premiere Pro CC 2018 Dolby Audio Problem
The main specs. of my computer are:
Processor:                         Intel Core i7  950 @ 3.07 Ghz
Installed Memory (Ram):  12 GB.
System Type:                    Windows 7 Ultimate 64 bit
Graphics Card:                  Nvidia Geoforce GTX 7 70
Plug-ins                             Red Giant
I was using PrPro CC 2015.3 with no problem at all. After reinstalling Windows 7, I wanted to try the new Adobe PrPro CC 2018 and here the problems started as I could not open my projects which were created using the PrPro CC 2015.3 and I got an error message: " the selected file could not be linked because its type (video) does not match the original file's type (video and audio)"  After doing some research I could find that the reason of this problem was the the newest version of Adobe PrPro does not support the Dolby Audio  !!!!!!!!!  I couldn't find a correct solution for this. Adobe respected staff, Can anyone help please?
Thanks in advance.
    excited_Genie16B8Correct answer
    Nov 7, 2017 11:56 PM UTC
    Nov 10, 2017 1:20 PM UTC
    Hey,
    we have the same problem with Dolby-Audiodecoder . . .
    Error:
    Please help us fast!!
    Nov 7, 2017 11:09 PM UTC
    I consumed a lot of time to research this issue and most probably the reason of the above error is the absence of the Dolby Audio decoder because of my update to PrPro CC 2018
    Kona_Bob
    Nov 8, 2017 12:01 AM UTC
    That's my impression also.
    I have not upgraded to PPro 2018 due to all of the problems noted on this forum, so I have no first hand experience.
    However, it seems that PPro 2018 will rely on the operating system to have functioning Dolby decoder rather than providing that codec in as it has done in the past.
    Also looks like the problem is more complicated if you are running Win 7 as it also has no Dolby decoder.
    Nov 8, 2017 7:04 PM UTC
    This Dolby Audio issue is so disappointing. Moreover, after contacting Adobe support I got no help at all other than requesting me to update the OS. I regret the time I consumed talking to them. Adobe Customer support staff denied what is written on Minnetonka's  web site mentioning that the Adobe representative will supply Adobe users with an 8‐digit coupon code for the Minnetonka Dolby Audio decoder to be for free and not paying the $295 to purchase (which is already over priced)
    You can check the link here
    Adobe CC Support Page - TLS Corp
    Very disappointing Adobe.
    Kona_Bob
    Nov 7, 2017 10:41 PM UTC
    There is lots of very recent info about this
    Just search the forum for "Dolby"
    Nov 7, 2017 11:00 PM UTC
    Kona, I already searched the forum and they are mostly not giving any correct solution, the following is an example:
    We want Dolby back again
