Sven_Ravensbergen
Adobe Premiere Relink Media on SMB Share - 2025/2025 Speed Difference
  • March 8, 2026
  • 109 views
Hi Adobe Team,
I’ve run into a significant performance issue with the new Premiere Pro 2026 (v26.0.1) regarding media relinking over SMB, which seems to be a clear regression compared to the 2025 (2025.6.4) version.
The Issue
In Premiere Pro 2025, the initial relink/indexing of a large project (multiple TBs) takes some time, but once the metadata is cached, subsequent launches are fast, but still takes some unnecessary time.
In Premiere Pro 2026, this "warm-up" benefit is gone. Every single time I open the project, Premiere spends the same full duration relinking and scanning the media. It’s as if the application is failing to commit the file-path metadata to the local cache or is forcing a deep re-scan on every launch, regardless of whether the files have moved.
My Setup
I’ve tested this thoroughly on a high-end setup to rule out hardware bottlenecks:
  • Clients: New Mac Studio M4 Max (14/40-cores), 128GB RAM.
  • Network: 10GbE to clients, 100GbE uplink to the switch.
  • Configuration: MTU 9000 (Jumbo Frames) enabled throughout.
  • Storage: All-NVMe QNAP and TrueNAS (SMB shares).
Test Results & Observations
  • Initial Scan: Both 2025 and 2026 take roughly the same time for the first scan.
  • Subsequent Launches: 2025 drops to just a 15-20 seconds. 2026 stays at the original slow speed (several minutes for large projects).
  • Cache Clear: Clearing the media cache resets 2025 to the "slow" state (as expected), but after one run, it’s fast again. 2026 never gets faster.
Has anyone an idea?
    jamieclarke
    Hi ​@Sven_Ravensbergen -   Thanks for submitting your bug report. We need a few more details to try to help with the issue.
    Can you check this article: Turn off packet signing for SMB 2 and SMB 3 connections
    Let us know if it helps your issue.  There is always some weirdness with SMB and different versions of macOS.
    Hi Jamie,
    We are running of a Facilis network storage with 10G ethernet and are using Premiere Pro 2024 on macOS Sequoia.  After testing Premiere 2026, the relink process is significantly slower.  As a comparison, a big project that took 2 minutes to link in PPro2024 is taking over 5 to 6 minutes in PPro2026.
    We would appriciate that new versions are not losing performance. This is one of the things that keeps us from upgrading.
    Are you aware of this?
    Thank you
    Sven_Ravensbergen
    @Joel5EB7
    @jamieclarke
    For reference, I’m having the same issues, all is my connection SMB based.
