Adobe Premire Pro 2019: Default Transition Unavailable
  • April 16, 2023
  • 4 replies
  • 3182 views
I've been using and learning Premire Pro for a few years, and I've encountered a problem that I've seen no one talk about online. At some point a few months ago, I unknowingly set my default transition (The basic fade in effect) to additive dissolve which isn't what I want. I went into my transition librbary and clicked on the square to unset it and tried to find the simple fade in effect which I believe is the cross disolve transition, but it when I playback the video, it doesn't transition with the simple fade I always had as my right click transition. I went through every single transition in my library and none of them is the transition I want. I've been trying to deal with this since and now I can't take it anymore. Any help is greatly appreciated, and let me know if I need to elaborate on things.
(P.S. I'm using Premire Pro 2020 in case that has something to do with it_
Correct answer Stan Jones
Don,
Here's what I think was happening in your search. I had a similar issue recently. You immediately found what you were looking for, the cross dissolve, but thought it was not working because your two clips were one clip razored into two parts.
If you had 2 different clips with no handles (even the same clip, but the start of the second instance placed at the end), you'd get a warning about no handles.
But when you razor a clip, the first part has, as "handles," all the second part. And the second part has handles before it. So you get no warning, the transition looks okay on the timeline, but....  You see no transition because the before and after are identical. The frame from clip 1 that is being transitioned to the frame in clip 2 are identical.
As you later said, it was working for a fade in/fade out - if placed at the beginning of a clip or the end. And you would have seen that it was working in between clips if they had not had identical content because they were razored.
Stan
Stan Jones
Stan JonesCommunity ExpertCorrect answer
Don,
Stan
Sorry for the late reply again, but it finally worked! I made a copy of the first clip to give it handles and once I added the cross disolve effect, the two clips finally have transitioned smoothly! I've never even heard about handles until today! Thank you all for helping me! Here's hoping that other people who have the same issue as I did find this discussion board!
That is what I said: no handles.
And when posting a screenshot about transitions in the effect controls. Post the entire panel, especially the right side.
Peru Bob
Delete the Media Cache and Media Cache files:
https://community.adobe.com/t5/premiere-pro/faq-how-to-clear-your-media-cache-in-30-seconds-in-premiere-pro-2020/m-p/11017257/thread-id/260446?page=1
If that doesn't work, try resetting the preferences:
https://community.adobe.com/t5/premiere-pro/faq-how-to-reset-trash-preferences-in-premiere-pro/td-p/8236158?page=1
Reset a workspace
1. Do one of the following:
• Click the Workspace menu icon and select Reset to Saved Layout.
• Choose Window > Workspace > Reset to Saved Layout.
from here:
If that doesn't work, try Preferences > Audio Hardware and set Input to None.
If that doesn’t work, try updating or rolling back your graphics driver directly from the video card manufacturer’s site. If NVIDIA, do a clean installation of the latest Studio Driver (NOT the Game Driver)
If that doesn't work, try creating a new project and import the old one into it.
Went through most of what you suggested, haven't updated the graphics driver or checking warp stabilizer yet, but the cross dissolve transition still doesn't work as intended when I tried everything else. However I found out that the cross dissolve does work if it's at the start or an end of a clip, it's just that it doen't work between two clips which is what I need. Thanks for helping by the way! I very much appreciate it even if the issue isn't corrected yet!
Peru Bob
Do you have Warp Stabilizer or Time Remapping applied to either clip?
Peru Bob
Try unchecking Composite in linear color in the sequence settings.
Also, if there is a red line above the timeline, try pressing Enter to render the timeline and turn the red line above the timeline to green.
Apologies for the late reply, I did as you said, but no luck unfortuneatley, and the line is all yellow currently.
