After Effects Project in Premiere Timeline > Fonts not loading.
Hey guys,
I'm having a weird problem.
Our workflow in our company is:
We edit on premiere > Import into AE > and bring back the AE sequence into the PR project to export.
So far with the occasional problem here and there all has been good.
The main font we use in the company is Museo Sans, It's an adobe font so all is good.
Since Friday every time I'm trying to render exports AME says that the font is not installed.
Then I get a bit of a weird droopy situation.
PR loads project and when browsing Font is disconnected (see the text with a different font)
If I open AE (from the project and not cmd+e) font loads perfectly. > PR projects updates, but render won't work will still not show the font.
If I open AE (from cmd+e) font doesn't load and will say [Museosansrounded-700/type1] if I update it, then it's fixed.
bear in mind, I have 500 projects, with different AE files so it would be a DOOM to have to update this one by one...
I just checked version 23.5 and this doesn't happen
Any clue? This issue is driving me crazy.
Best,
Erik
