After exporting, a few random audio clips have no sound.
In particular, the clips that changed the audio level are more likely to do so.
I'VE BEEN STRUGGLING WITH THIS FOR DAYS.
there is absolutely nothing wrong with the export settings and it matches the sequence settings.
I even tested it with inconsistent settings, but the result was the same.
(Sequence 48,000 hz, Export 41,000 hz or conversely)
I've searched the disscusion community and this error seems to have been going on for years. (2018~)
Are you kidding me? It's 2023 now.
Should I set the audio format to MPEG and not AAC?
I tried nesting the audio clips and making changes to the audio tracks.
Even though I created a new project and copied and pasted everything in there.
But there is no answer, what the hell is wrong?
please save me, if there is anyone who solved this problem.
Title edited by mod to reflect issue.
