after speed up hold frame doesn't work properly
- Issue When adding a frame hold on a speeded up clip the frozen frame comes from another point of the video corresponding to the video at normal speed i believe
- Adobe Premiere Pro version number: Version 24.4.1 (Build 2)
- Operating system - Windows 11
- System Info: CPU, GPU, RAM, HD:
AMD Ryzen 9 7950X3D 16-Core Processor
NVIDIA GeForce RTX 4080 SUPER
64Gb
KINGSTON SNV2S2000G
- Steps to reproduce - (Very important!) put a video on the timeline, speed up the video 500% then cut the last frame and add a hold on it
- Expected result - Get a frozen frame of the video following the last one in the non frozen speeded up video
- Actual result - The frozen fram comes from another part of the video
